04-17-2010, 15:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | iphone 3Gs : No network [Hardware Problem] am trying to solve this one up without success. Tried replacing the PA and antenna switch... still the same. Cannot call 112. Did custom firmware.... starts searching... and then No Service. It is 100% hardware related. Anyone have any experience on this issue pls? Please do not reply with do restore or use blackrain etc etc as all these have been tried and no success. thanks for any help |
04-17-2010, 18:14 | #5 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 936896 Status: Offline Thanks Meter: 14 | same problem with my iphone 3g ...no signal i think its firmware related and not hardware ....because if you have changed the antenna and it still does not work it means that its software related. check the baseband modem version, it shouls be 5.12.01 ,if yes you will have to wait as there is no unlocking solution at the moment what is the 3310 trick? |
04-17-2010, 19:14 | #6 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | baseband is 5.11.07. It is hardware related as there is Searching... shown going on. when it is a software problem it will just shows Searching... for a split of a second and then nothing. Also if it is software related if not mistaken it will call 112. so that leaves only 1 problem source.... hardware ...damn |
04-20-2010, 03:01 | #7 (permalink) | |
Junior Member Join Date: Jan 2010
Member: 1217817 Status: Offline Thanks Meter: 1 | Quote:
Does it software related or Hardware related? Without wifi for now 2-3 months. Please help. Thanks in advance. | |
04-20-2010, 09:29 | #8 (permalink) | |
Member: 11325 Status: Offline Thanks Meter: 266 | Quote:
04-27-2010, 16:27 | #9 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
after restore original frimware it activate itselft , i have signal only on 2 out of 3 networks in here , mostly in umts network it seem , also signal is very very law , only like 1 line. also no wifi . any ideas ? like i said i have some signal but very poor | |
08-30-2010, 11:06 | #10 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1379022 Status: Offline Thanks Meter: 0 | Same problem Hi Burnt cobba I am having the same problem showed it to couple of tech guys they say the network IC has gone short and it cannot be replaced.. I still some times when in open area get network and able to make calls and receive but that is not solution... Just wondering did u get any solution for the same... thanks |
11-14-2010, 16:34 | #12 (permalink) |
Junior Member Join Date: Nov 2010 Location: rus spb Age: 45
Member: 1438249 Status: Offline Thanks Meter: 2 | on ifone 3g network if the bad-replace antenna svicher (green small sandwich) if the net catches only in 3g mode, then replace the power Amp.Modyl |
The Following User Says Thank You to MAD REMONTNIK For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
