12-27-2008, 20:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Iphone is disabled - sim locked i received an iphone which appear on startup and show IPHONE IS DISABLED - SIM LOCKED fone cant connect wiz itune... any1 can help me wiz easy steps!!? Thnx |
12-27-2008, 21:14 | #4 (permalink) |
Registered User Join Date: Apr 2006 Location: near to hyderabad ap india
Member: 259742 Status: Offline Thanks Meter: 215 | iphone in recovry mode,itunes errors what should be done How to Put an iPhone Into DFU Mode DFU means Device Firmware Update. If a restore using Recovery Mode doesn't work you will want to use DFU Mode as a last resort. When placing your iPhone into DFU Mode it does not load the OS before attempting the restore Watch the Video! For your convenience this tutorial is available in video format also. Click the Watch It button to view the tutorial! To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps: Step One Open iTunes and connect the iPhone to your pc Step Two Press and hold the Home button and the Sleep/Wake button at the same time. Step Three After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode. The iPhone screen will remain black like this: NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long! after that itunes will detect ur phone,then try to restore with customised firmware |
The Following 2 Users Say Thank You to prasad3223 For This Useful Post: |
12-28-2008, 02:07 | #6 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | ur iphone is BLANK after u will succeffuly downgrade it u will get No imei no wifi no Baseband use search in forum &U will get what u need |
12-28-2008, 11:12 | #12 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | i will do this >> iPhone Error 1015 and 1013 during Downgrade Let it restore and eventually you will get a "Unknown error occurred" (1015). Now you have a 1.1.1 iPhone with the 1.1.2 modem firmware. Now you need to enter DFU restore mode.Hold home and sleep buttons and when the screen turns black let go of sleep and keep holding home. iTunes will recognise this and you will hold shift and click restore and navigate to 1.0.2 firmware files. Let it restore and you will get a "Unknown error occurred" (1013) and the yellow triangle should pop up. The hard bit is over - you're nearly there! is it ok ?? |
12-28-2008, 14:28 | #13 (permalink) |
Member: 259742 Status: Offline Thanks Meter: 215 | ok u have 2 choices 1) u do one thing use winpwn2.5 to make a customised firmware at the end of process u will be promted how to put iphone in dfu mode,do that u will be left with white screen on ur iphone.AND winpwn says to restore with itunes .(this is spl DFU mode) try to restore with any firmware(ur wish). 2)i personally recomend u u to download this torrent file and restore b'cos with this customised firmware u will get lot of things,activated,jailbreaked mobileinstallation pfile some applications within this custom fw.give it atry http://thepiratebay.org/torrent/4402...hema(aka_Santt u will get all this direct unlock 2G phone/jailbreak/activate/cracked mobileinstallation with just restore button Tweaks: - activation/jailbreak; - root size 1,3Gb; - custom charger image(lock-screen); - custom "Notes" font (Sergoe); - custom System font (Times New Roman); - Safari Download Plugin; - patched MobileInstallation 2.1 - for installing cracked *ipa; - Music and Video icons like on iTouch; - add to Restrictions SMS, Mail, Maps, Stocks, Cydia, Installer, Contacts, Videos, Photos, AppStore(only hide icon); - broadened Settings; - vibration on typing; - autocorrection off; - custom Dock image; - custom WiFi image; Apps: - textReader 2.1; - Cydia; - Converter; - Installer; - SlovoED(EN-RU-EN); New: - mobileFinder - русифицирован, доступ ко всем папкам; - WiFi Toogle - быстрое вкл/выкл WiFi, можно назначит на двойное нажатие "Home"; - BossPrefs Safari Sownload Control; - Cycoder; - NewsStand; - ruBooks 0.912(2); - Terminal; |
12-28-2008, 16:28 | #14 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Pakistan Peshawar Age: 35
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | hi i got that problem too but i just restored the iphone with itunes 7.5 and then unlocked with ilberty+ and phone was working very well |
Iphone is Disabled | 07heaven | iPhone 4 / iPhone 4S | 23 | 08-11-2010 15:23 |
Problem: iphone is disabled | junxea | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 10-04-2008 15:18 |
Iphone is disabled Help me ...... | uttam | iPhone 2 / iPhone 3G / iPhone 3GS | 9 | 09-29-2008 14:50 |
iphone is disable | ..::proudcracker::.. | iPhone 2 / iPhone 3G / iPhone 3GS | 9 | 07-28-2008 13:13 |
N500 - disable SIM Lock , need help | alyrd | SYSOL Platform | 0 | 04-25-2005 01:37 |
