Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 04-02-2016, 07:38   #61 (permalink)
Crazy Poster
Member: 2553855
Thanks Meter: 5
Can we unlock SM-G530T1 metropcs (Grand prime) using sarasoft hwk?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 04-02-2016, 08:47   #62 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
No,SM-G530T1 Metropcs not supported for unlock at moment.
Old 04-02-2016, 08:59   #63 (permalink)
Member: 2530556
plz add Direct Unlock LG-VS876
Old 04-02-2016, 09:17   #64 (permalink)
anuhya anu's Avatar
Member: 2540337
Thanks Meter: 39
Originally Posted by Unlocker AL View Post
where can i found Motorola flash files ?
please you can add some flash files in support
for exemple Motorola,Htc,Sony
thx anyway for your job
Yes it will soon add in suppurate support area
Sent from my LS-5503 using Tapatalk
Old 04-02-2016, 11:42   #65 (permalink)
Member: 2349975
Thanks Meter: 51
Android USFT does not connect to my usf box but it connects to other usf softwares like SAM, LG etc, what should i do next, see log;
for UFST and UFS Turbo Only.
v 1.0.4.4
More Common Functions Added in [ADB] ToolsTab:
Deal with Partitions and Files (Write, Wipe, Reset FRP) need Root Rights.
Non Root [Reset FRP] for LG and Samsung Models.
More Functions Enabled in [OEM] ToolsTab:
[Read E2P], [Write E2P] for Samsung Models.
More LG Models Added:
AS985, AS990, AS991, AS995, F600K, F600L, F600S, H650, H650AR, H650E, H650K,
H900, H901BK, H960A, LS740, LS885, LS980, LS990, LS991, LS995, LS996, MS323,
MS345, MS395, MS631, US990, US991, US995, V935, V935T, VS880, VS990
More Motorola Models Added:
XT1002, XT1003, XT1008 (Moto G 1st. Falcon)
XT1019, XT1021, XT1022, XT1023, XT1025 (Moto E 1st. Condor)
XT1030 (Droid Mini Obakem)
XT1049, XT1050, XT1052, XT1053, XT1055, XT1056, XT1058, XT1060 (Moto X Ghost)
XT1080, XT1080m (Droid Ultra / Maxx Obake)
XT1085, XT1092, XT1093, XT1094, XT1095, XT1096, XT1097, XT1098 (Moto X 2nd. Victara)
XT1100, XT1103 (Nexus 6 Shamu)
XT1115 (Moto X Pro Shamu)
XT1225, XT1250, XT1254 (Moto Maxx / Droid Turbo Quark)
XT1505, XT1506, XT1511 (Moto E 2nd. Otus)
XT1514, XT1521, XT1523, XT1524, XT1526, XT1527, XT1528, XT1529 (Moto E 2nd. Surnia)
XT1561, XT1562, XT1563, XT1565 (Moto X Play / Droid Maxx 2 Lux)
XT1572, XT1575 (Moto X Style / Pure Clark)
XT1580, XT1581, XT1585 (Moto X Force / Droid Turbo 2 Kinzie)
More Samsung Models Added:
A310N0,
G9300, G9308, G930A, G930AZ, G930F, G930F-DS, G930K, G930L, G930P, G930R4,
G930R7, G930S, G930T, G930T1, G930V, G930W8, G930X, G9350, G935A, G935F,
G935F-DS, G935K, G935L, G935P, G935R4, G935S, G935T, G935V, G935W8, G935X,
J105M, J105M-DS, J111M, J120A, J320F-DS, J320FN, J320G, J320Y, J320YZ,
T280, T285, T375L, T375S, T3777, T377V, T677NK, T677NL, T677V
More Sony Models Added:
C5502, C5503, M36h, SO-04E (Xperia ZR / A Dogo)
C6502, C6503, C6506, L35h (Xperia ZL / ZQ Odin)
D5788, SO-04F (Xperia J1 Compact / A2 Altair)
SO-04G (Xperia A4 Ajisai)
SOL22 (Xperia UL Gaga)
Fastboot protocol 'Data Size Mismatch' Bug fixed.
Improved LG [Unlock] on some models (MSM8909 SoC, H410)
v 1.0.3.3
Added [OEM Utils] for FastBoot Flashing solution based Devices.
Added GPT Read using [Read Part.] (type GPT in path Requestor field)
Can also read any interesting memory part using:
dev/block/mmcblk0 bs=512 count=N seek=K (standard dd command options)
or Read any file, by specifying full path e.g.: MyFiles/Myfile.bla
v 1.0.3.0
F430L, UK410, V400, V410, V411, V490, V496, V497, V700, V700N, VK410, VK700,
VS980, VS985, VS985W, VS986
J105B, J105F, J105F-DS, J111F, J320M, J320M-DS
v 1.0.2.9
H960, H961, H962, H968 (V10)
LG LAF Models:
Added [Read Flash] Partitions by GPT (Can Select which ones want to Read)
Added [Write Flash] of Read Partitions using GPT Option.
Notes:
In this way can Backup / Restore Device without Root of Partitions
which contains some Vital Data: modemst1, modemst2, fsg, misc,..
Can Select Multiple Files but Cannot Select more than 1 DZ or TOT file.
Writing of PrimaryGPT and BackupGPT is not Allowed.
Do not Write BootFiles (sbl1, sbl2, sbl3, tz, rpm, hyp, sdi, aboot) Alone
if Version Mismatch between them, will Have 'Brick' !
Some Useful Hints:
LG
Always Read Hints by Moving Mouse on Control.
To Download KDZ Files use [Get Imei] or Enter IMEI and then use [Download]
To Repair 'Numbers' use [Byp.Security] and then [Gen.Settings] in [OEM] ToolsTab.
If Have Rooted Phone do [Read EFS] before any Security Action or
Backup Using [Read Flash] with GPT Option Selected if is a 'LAF' Model.
Do [Read ENVM] in [Diags] ToolsTab.
If have some Not Realised Phone, do Above Readouts and use [Developer] button
in [ADB] ToolsTab and send Result Files to Us.
Not Compatible Box Selected
Old 04-02-2016, 12:20   #66 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
Buy new UFST box to use this software.Old hwk box will not support this software
The Following 3 Users Say Thank You to mobileclinic For This Useful Post:
Old 04-02-2016, 15:29   #67 (permalink)
Crazy Poster
Member: 2553855
Thanks Meter: 5
SM G930T unlocking available?
Old 04-02-2016, 15:33   #68 (permalink)
Crazy Poster
Member: 2553855
Thanks Meter: 5
Moto XT1528 verizon bootloader unlocking available?
Old 04-02-2016, 17:07   #69 (permalink)
Member: 2298369
Thanks Meter: 440
Lg p715 flashing done sucessfully
LG P-715 FLASH SUCCESSFULLY-
File Format: TOT Type FFFFFFFF [LGP715]
Partitions (Chunks) to Flash: 13
LG P715 (L7 II DS) at USB (COM55) [LG FLASH 1] {Write Flash}
DL_MODE Failed: -2
DL IMEI1: 351647-06-171731-3
DL DVPID: CD22S140217000246
MEMPARMS: 3.64 GB in 512 Byte Blocks
Writing Partition 02: QCSBL
Writing Partition 03: OEMSBL
Writing Partition 04: EXT
Writing Partition 05: APPSSBL
Writing Partition 09: APPS
Writing Partition 12: MODEM
Writing Partition 13: MODEM_BACKUP
Writing Partition 14: SYSTEM
Writing Partition 15: PERSIST
Writing Partition 16: CACHE
Writing Partition 17: RECOVERY
Writing Partition 22: BOOT_LOGO_IMAGE
Writing Partition 26: rct
RESTART : 2
Flash Write Done in: 06:13.733
Old 04-02-2016, 17:55   #70 (permalink)
Crazy Poster
Member: 2553855
Thanks Meter: 5
What is the procedure to unlock SM-G930T (TMB)?
Or device app unlocking is the only solution?
Old 04-02-2016, 22:08   #71 (permalink)
Crazy Poster
Member: 2553855
Thanks Meter: 5
Missing folder: C: \Program Files (x86) \Sarasoft\UFS\ADB
How to fix this?
Old 04-02-2016, 22:59   #72 (permalink)
Crazy Poster
Member: 2553855
Thanks Meter: 5
What is the ideal RJ45 cable? Or any RJ45 Uart cable will work?
Old 04-03-2016, 04:53   #73 (permalink)
Member: 2444981
Thanks Meter: 11
hwk sarabox
hello friends can i use this software with hwk
Old 04-03-2016, 07:27   #74 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
SM-G930T is not supported for unlock at moment.App unlock via imei is only solution at moment.
Old 04-03-2016, 07:28   #75 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
How to fix this?
Use panel 2.3.0.7
Scan Box
Check Box
Check Server
Install (all missing files will be downloaded)
The Following User Says Thank You to mobileclinic For This Useful Post:
Page generated in 0.23898 seconds with 9 queries
