11-15-2017, 11:27 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | Redmi note 4 flash sucessfully Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM14) Flash Bundle: rawprogram0.xml SAHARA VERS: 2.1 SAHARA PROG: prog_emmc_firehose_8953_ddr_xiaomi2.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM14) Flash Bundle: rawprogram0.xml SAHARA Connect Fail: -3 FHREST DONE: Ok Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM14) Flash Bundle: rawprogram0.xml SAHARA Connect Fail: -3 Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM14) Flash Bundle: rawprogram0.xml SAHARA VERS: 2.1 SAHARA PROG: prog_emmc_firehose_8953_ddr_xiaomi2.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8953 FHPROG MEMT: eMMC FHINFO PAR0: 122142720 x 512 Sectors (58.24 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 Partitions to Write: 30 (3.16 GB) FWRITE DONE: ST 0x0000020000 modem 84 MB FWRITE DONE: ST 0x0000060012 sbl1 361.47 KB FWRITE DONE: ST 0x0000060412 sbl1bak 361.47 KB FWRITE DONE: ST 0x0000060812 rpm 170.38 KB FWRITE DONE: ST 0x0000060C12 rpmbak 170.38 KB FWRITE DONE: ST 0x0000061012 tz 1.41 MB FWRITE DONE: ST 0x0000062012 tzbak 1.41 MB FWRITE DONE: ST 0x0000063012 devcfg 36.85 KB FWRITE DONE: ST 0x0000063212 devcfgbak 36.85 KB FWRITE DONE: ST 0x0000063412 dsp 16 MB FWRITE DONE: ST 0x0000080C40 sec 80 Bytes FWRITE DONE: ST 0x00000A0000 splash 657.57 KB FWRITE DONE: ST 0x00000C0000 aboot 575.16 KB FWRITE DONE: ST 0x00000C0800 abootbak 575.16 KB FWRITE DONE: ST 0x00000C1000 boot 24.76 MB FWRITE DONE: ST 0x00000E1000 recovery 26.46 MB FWRITE DONE: ST 0x0000101800 system 3 GB (Unsparsed Size) FWRITE DONE: ST 0x0000720000 cache 256 MB (Unsparsed Size) FWRITE DONE: ST 0x0000880000 lksecapp 56.01 KB FWRITE DONE: ST 0x0000880100 lksecappbak 56.01 KB FWRITE DONE: ST 0x0000880200 cmnlib 196.56 KB FWRITE DONE: ST 0x0000880400 cmnlibbak 196.56 KB FWRITE DONE: ST 0x0000880600 cmnlib64 249.94 KB FWRITE DONE: ST 0x0000880800 cmnlib64bak 249.94 KB FWRITE DONE: ST 0x0000880A00 keymaster 220.71 KB FWRITE DONE: ST 0x0000880C00 keymasterbak 220.71 KB FWRITE DONE: ST 0x00008A0410 cust 832 MB (Unsparsed Size) FWRITE DONE: ST 0x0000A40410 userdata 9.31 GB (Unsparsed Size) FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Write Flash Done in: 11:02.736 |
The Following User Says Thank You to galaxycompue For This Useful Post: |
