12-23-2017, 22:16 | #1021 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_1.bin BR ComPort: COM14 BR Asic Id: MT0321 [0000] >> MT6735 BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 28000000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 484A019065314738BAB007052B4B2E5D [e1G8] PR Version: 4.2 [0x93] (5) MT8735 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000001D2000000 [7.818.182.656] eMMC CID : 90014A48384731650507B0BA5D2EB22B [H8G1e] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 5010095C86E8CC658B7A854A08C614FF PMT (GPT) Found : 28 Partition Entries Reset FRP Done in: 00:03.471 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
12-23-2017, 22:17 | #1022 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Var VIVO-Y13L (Y13L LTE DS) at USB (COM65) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Aug 16 201614:36:07Jul 23 201501:00:00EAAAANVZ MDMBUILD: MPSS.DPM.1.0.c7.8-00039-M8916EAAAANVZM-1 NV IMEI1: 866726-02-700858-3 NV IMEI2: 866726-02-700857-5 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 Gen.Settings Write Done: 2 Item(s) Var VIVO-Y13L (Y13L LTE DS) at USB (COM65) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Aug 16 201614:36:07Jul 23 201501:00:00EAAAANVZ MDMBUILD: MPSS.DPM.1.0.c7.8-00039-M8916EAAAANVZM-1 NV IMEI1: 356656-76-556445-4 NV IMEI2: 354656-57-576757-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 |
12-23-2017, 22:18 | #1023 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Sony D2303 (Xperia M2 LTE Eagle) at USB Auto Select [S1] {Write Flash} Files to Flash: 1 USB DEV : SEMC [USB\VID_0FCE&PID_ADDE\6&6f0c48d&0&1] BL VERS : S1_Boot_MSM8x26_LA1.0_36 BL PKTSZ: 0x00010000 BL IMEI : 353255-06-092071-0 BL ROOTS: ROOTABLE TA MODEL: D2303 TA DEVSN: ZH8002V2J9 TA CDVER: 1281-1576_R1B TA SWVER: 1278-3081_18.3.1.C.1.17 TA FLVER: GLOBAL-LTE_18.3.1.C.1.17 Loader Boot Done in 00:00.282 FL VERS : LOADER_RELEASE_MSM8X26_31_AID_4 FL PKTSZ: 0x00080000 FL IMEI : 353255-06-092071-0 TA MODEL: D2303 TA DEVSN: ZH8002V2J9 TA CDVER: 1281-1576_R1B TA SWVER: 1278-3081_18.3.1.C.1.17 TA FLVER: GLOBAL-LTE_18.3.1.C.1.17 TA S1VER: 1274-7024 S1_Boot_MSM8x26_LA1.0_36 TA FTIME: 2017-10-05 11:16:20 AT PLFRT: B77943D5B24F7012CB12EB2FF857C69EAA6518C0E58957AA70 C0B0590E1F3BCA AT OTLCK: LOCKED AT OTDAT: 01000400 AT IDCOD: 108050E1 Writing File: userdata.sin File Write Done in 00:09.309 + 00:09.059 Shut Down Ok All Done in 00:29.835 |
12-23-2017, 22:23 | #1024 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Alcatel 6070D (Idol 4S LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM30) SAHARA VERS: 2.1 SAHARA PROG: prog_emmc_firehose_8976_alc.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8976 FHPROG MEMT: eMMC FHINFO PAR0: 61071360 x 512 Sectors (29.12 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 1 FHREST DONE: Ok Reset FRP Done in: 00:01.384 (2) |
12-23-2017, 23:17 | #1025 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Samsung SM-A320FL (A3 (2017) LTE) at USB [ADB] {Reset FRP} daemon started successfully * 52035d5ec0d1248b device Goto "Backup and reset" Menu and make "Factory data reset" PROCEDURE : FLASH FULL COMBINATION AND FULL FIRMWARE BUT NOTE THE FOLLOWING SBOOT=COMBINATION PARAM=STOCK CM=STOCK BOOT=COMBINATION RECOVERY =COMBINATION SYSTEM=STOCK HIDDEN=COMBINATION CACHE=STOCK LOG FROM COMBIATION FLASH Samsung SM-A320FL (A3 (2017) LTE) at USB (COM12) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-A320FL_Read.pit No Partition Info for Image: nad_fw.bin, in COMBINATION_OXA_FA60_A320FLXXU1AQH1_OXAFAC_CL11575 786_QB14782241_REV00_user_mid_noship.tar.md5 No Partition Info for Image: a3y17lte_eur_open_fac.pit, in COMBINATION_OXA_FA60_A320FLXXU1AQH1_OXAFAC_CL11575 786_QB14782241_REV00_user_mid_noship.tar.md5 Warning, Pit Image: a3y17lte_eur_open_fac.pit Skipped, Use [Re-Part.] Option with Pit Image File: COMBINATION_OXA_FA60_A320FLXXU1AQH1_OXAFAC_CL11575 786_QB14782241_REV00_user_mid_noship.tar.md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x001A6110 (1.65 MB) Partition: PARAM, Image: param.bin, Size: 0x000D2000 (840 KB) Partition: CM, Image: cm.bin, Size: 0x00255110 (2.33 MB) Partition: NAD_REFER, Image: nad_refer.bin, Size: 0x00010000 (64 KB) Partition: BOOT, Image: boot.img, Size: 0x01088120 (16.53 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x010FE920 (16.99 MB) Partition: SYSTEM, Image: system.img, Size: 0x3D2F8230 (978.97 MB) Partition: RADIO, Image: modem.bin, Size: 0x0244F2D0 (36.31 MB) Partition: CACHE, Image: cache.img, Size: 0x0059C110 (5.61 MB) Flash Write Done: 00:59.695 NOW LOG FRROM STOCK FLASH Samsung SM-A320FL (A3 (2017) LTE) at USB (COM12) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-A320FL_Read.pit No Partition Info for Image: a3y17lte_eur_open_hidden250m.pit, in CSC_VFG_A320FLVFG1AQA1_CL10111114_QB12246976_REV00 _user_low_ship.tar.md5 Warning, Pit Image: a3y17lte_eur_open_hidden250m.pit Skipped, Use [Re-Part.] Option with Pit Image File: BL_A320FLXXU1AQA8_CL10121246_QB12311408_REV00_user _low_ship.tar.md5 Partition: PARAM, Image: param.bin, Size: 0x000D2000 (840 KB) Partition: CM, Image: cm.bin, Size: 0x00255110 (2.33 MB) File: AP_A320FLXXU1AQA8_CL10121246_QB12311408_REV00_user _low_ship.tar.md5 Partition: SYSTEM, Image: system.img, Size: 0xE01D6590 (3.5 GB) File: CSC_VFG_A320FLVFG1AQA1_CL10111114_QB12246976_REV00 _user_low_ship.tar.md5 Partition: CACHE, Image: cache.img, Size: 0x04DFC120 (77.98 MB) Flash Write Done: 03:46.910 Restart Done DO NOT REPARTITION BY PIT THIS SHOULD ENABLE ADB AND DO FRP RESET BY ADB THIS IS REPORTED TO CATER FOR MOST 30/2017 SAMSUNG... DEVICES PROVIDED THEY DO NOT INCLUDE A USERDATA PARTITION IN THE FIRMWAREEEEE why chose ufst for this work it mounts adb sniffers on ur pc and it keps searching for any adb enabled devices unlicke other tools where u need to specify the devices ur self so with ufst asa soon as the drivers are mounted correctly it will do the work evn if a device has a reboot lop due to firmware juggling it will do the workk Last edited by ferouz kassim; 12-23-2017 at 23:27. |
The Following 3 Users Say Thank You to ferouz kassim For This Useful Post: |
12-23-2017, 23:54 | #1026 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | ALCATEL 6070K UNBRICK DONE BY UFST NO NEED TO JTAG SOLDERWIRED AND SO ON JUST PLUG SB AND CRUISEE Alcatel 6070K (Idol 4S LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM44) Flash Bundle: Rawprogram0.xml SAHARA VERS: 2.1 SAHARA HWID: 009900E100420030 [MSM8976] SAHARA HASH: 28DCF6543D791D8E476B3D72CCDEB4E7EE744F6015CAE8CB47 D8D83E2BCEE87E SAHARA SERN: 00AE9A34 (11442740) SAHARA PROG: prog_emmc_firehose_8976_alc.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8976 FHPROG MEMT: eMMC FHINFO PAR0: 61071360 x 512 Sectors (29.12 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 1 Partitions to Write: 22 (27.51 MB) FWRITE DONE: ST 0x0000061812 sbl1 313.59 KB FWRITE DONE: ST 0x0000061C12 sbl1bak 313.59 KB FWRITE DONE: ST 0x0000062012 rpm 163.07 KB FWRITE DONE: ST 0x0000062412 rpmbak 163.07 KB FWRITE DONE: ST 0x0000062812 tz 637.4 KB FWRITE DONE: ST 0x0000063812 tzbak 637.4 KB FWRITE DONE: ST 0x0000064812 hyp 72 KB FWRITE DONE: ST 0x0000064C12 hypbak 72 KB FWRITE DONE: ST 0x0000070812 splash 4 MB FWRITE DONE: ST 0x0000081040 sec 80 Byte FWRITE DONE: ST 0x0000081060 aboot 563.21 KB FWRITE DONE: ST 0x0000081860 abootbak 563.21 KB FWRITE DONE: ST 0x000095E8A0 cmnlib 164.46 KB FWRITE DONE: ST 0x000095EAA0 keymaster 173.41 KB FWRITE DONE: ST 0x000095ECA0 cmnlibbak 164.46 KB FWRITE DONE: ST 0x000095EEA0 keymasterbak 173.41 KB FWRITE DONE: ST 0x0000960000 cache 256 MB (Unsparsed Size) FWRITE DONE: ST 0x00009E0000 persist 32 MB (Unsparsed Size) FWRITE DONE: ST 0x00009F1C00 tctpersist 50 MB (Unsparsed Size) FWRITE DONE: ST 0x0000A0BA00 mdtp 3.6 MB FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Write Flash Done in: 00:55.657 |
12-25-2017, 08:22 | #1029 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | MTK IMEI REPAIR VIA ADB DONE Lenovo A850 (A850 3G DS) at USB [ADB] {Gen.Settings} daemon started successfully * 0123456789ABCDEF device Superuser Permissions Granted (SU) MD_CHIPS: MT6582, E01 MD_BOARD: LENOVO82_WET_JB5_HSPA_HW MD_SWVER: A850.V13 MD_IMEI1: --- MD_IMEI2: --- Gen.Settings Write Done: 2 Item(s) Lenovo A850 (A850 3G DS) at USB [ADB] {Factory Info} daemon started successfully * 0123456789ABCDEF device Superuser Permissions Granted (SU) MD_CHIPS: MT6582, E01 MD_BOARD: LENOVO82_WET_JB5_HSPA_HW MD_SWVER: A850.V13 MD_IMEI1: 354426-35-476453-1 MD_IMEI2: 354426-34-443553-1 |
12-25-2017, 14:02 | #1030 (permalink) |
Freak Poster Join Date: Mar 2009 Location: MUMBAI Age: 35
Member: 987290 Status: Offline Sonork: 100.1653649 Thanks Meter: 48 | intex cloud s9 frp done MTK MT6737M (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM68 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 510001154D333238FC4C00428DA38D96 [M328] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000003A3E00000 [15.634.268.160] eMMC CID : 150100513832334D42004CFC968D738D [Q823MB] ERAM Size : 0x0000000080000000 [2.147.483.648] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : CE26AD6EA711734DAF4AB0F5F5BE7DFA PMT (GPT) Found : 25 Partition Entries Reset FRP Done in: 00:02.812 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to GSM_IMRAN For This Useful Post: |
12-29-2017, 22:52 | #1034 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Huawei G730-U10 (Ascend G730 3G DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6582_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA_H1352.bin BR ComPort: COM7 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 BR Fuse Id: 00000380 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 90014A4834473164048602A4020B9177 [H4G1d] PR Version: 4.2 [0x87] (4) MT6582 eMMC BOOT1: 0x0000000000200000 [2.097.152] eMMC BOOT2: 0x0000000000200000 [2.097.152] eMMC RPMB : 0x0000000000200000 [2.097.152] eMMC USER : 0x00000000E7000000 [3.875.536.896] eMMC CID : 90014A4834473164048602A4020B9177 [H4G1d] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : D3532476E86AD8391681ED5836CDC3D9 PMT (EBR) Found : 22 Partition Entries Partitions to Flash: 12 (3.56 GB) Write PMT Done Write PRELOADER 20 MB, Skipped Write MBR 512 Byte, Done in: 00:00.424 Write EBR1 512 Byte, Done in: 00:00.310 Write PRO_INFO 3 MB, Skipped Write NVRAM 5 MB, Skipped Write PROTECT_F 10 MB, Skipped Write PROTECT_S 10 MB, Skipped Write SECCFG 128 KB, Skipped Write UBOOT 287.79 KB, Done in: 00:00.426 Write BOOTIMG 4.62 MB, Done in: 00:01.302 Write RECOVERY 5.48 MB, Done in: 00:02.080 Write SEC_RO 6 MB, Done in: 00:02.199 Write MISC 512 KB, Skipped Write UART_LOG 6 MB, Skipped Write LOGO 347.61 KB, Done in: 00:00.388 Write EBR2 512 Byte, Done in: 00:00.303 Write EXPDB 10 MB, Skipped Write ANDROID 916.3 MB, Done in: 07:18.602 Write CUST 147.34 MB, Done in: 01:04.182 Write CACHE 6.02 MB, Done in: 00:03.367 Write USRDATA 18.34 MB, Done in: 00:09.229 Write BMTPOOL 21 MB, Skipped Write Done in : 08:43.035 DA Shutdown Done, Disconnect Cable |
12-30-2017, 00:18 | #1035 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | LUA-U22 DEBRICK DONE AFTER ONE OF THE TOOLS TRY TO RESET FRP AND BRICK IT huawei LUA-U22 (Y3c II 3G DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6582_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : DA_LUNA_KEY.bin BR ComPort: COM24 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 BR Fuse Id: 00000380 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 90014A483847316505074DB04A54B337 [H8G1e] PR Version: 4.2 [0x87] (5) MT6582 DRAM Confg: 484A019065314738B04D070537B3544A EMI PreLdr: preloader_wt96582_s96582aa51.bin EMI TagVer: 12 DRAM Enabl: 02000000000040000000 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000001D2000000 [7.818.182.656] eMMC CID : 90014A483847316505074DB04A54B337 [H8G1e] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 9713E237F639CEE0A963FA14E7C333CC DA USB Com: Vid_0e8d&Pid_2001 (DA HighSpeed) PMT (EBR) Found : 23 Partition Entries Partitions to Flash: 13 (4.46 GB) Write PMT Done Signatures Set: 12/13 Write PRELOADER 115.57 KB, Done in: 00:00.468 Write MBR 512 Byte, Done in: 00:00.296 (Signed) Write EBR1 512 Byte, Done in: 00:00.297 (Signed) Write PRO_INFO 3 MB, Skipped Write NVRAM 5 MB, Skipped Write PROTECT_F 10 MB, Skipped Write PROTECT_S 10 MB, Skipped Write SECCFG 128 KB, Skipped Write UBOOT 308.25 KB, Done in: 00:00.281 (Signed) Write BOOTIMG 4.52 MB, Done in: 00:00.811 (Signed) Write RECOVERY 5.3 MB, Done in: 00:00.952 (Signed) Write SEC_RO 132.25 KB, Done in: 00:00.312 (Signed) Write MISC 512 KB, Skipped Write LOGO 700.25 KB, Done in: 00:00.296 (Signed) Write EBR2 512 Byte, Done in: 00:00.297 (Signed) Write CUSTOM 8.11 MB, Done in: 00:03.057 (Signed) Write EXPDB 10 MB, Skipped Write ROOTM 4 MB, Skipped Write FRP 1024 KB, Skipped Write ANDROID 1.71 GB, Done in: 05:37.661 (Signed) Write CACHE 5.98 MB, Done in: 00:01.917 (Signed) Write USRDATA 26.51 MB, Done in: 00:05.655 (Signed) Write BMTPOOL 21 MB, Skipped Write Done in : 05:52.616 Signatures Updated: Ok DA Shutdown Done, Disconnect Cable |
