03-02-2020, 18:03 | #1591 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | Quote:
-=MR_Gsm=- | |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
03-03-2020, 12:45 | #1592 (permalink) | |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | Samsung SM-G920F (S6)------{Write Flash} DONE Quote:
BR, -=MR_Gsm=- | |
03-04-2020, 15:13 | #1593 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Karachi
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | Var QMOBILE-XLi FRP Remove Done Var QMOBILE-XLi (XLi LTE DS) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [Fdl] SC7731E_Mobic_Astro_fdl Hold Vol+, Vol- and Insert Cable to Switched OFF Device FDLA: 50002E00, 9EFFFE00 FDLI: SA2E6954F7A7BBC8F3 FDLI: SA966BEC655DA91478 SROM: SPRD3 FDL1: Spreadtrum Boot Block version 1.1 FDL2: Ok, 96, v1.1 Reset FRP Done in: 00:00.290 Restart Done, Disconnect Cable All Done in: 00:09.252 |
The Following User Says Thank You to kashif ali For This Useful Post: |
03-05-2020, 11:23 | #1594 (permalink) | |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | Samsung SM-J330GCustom Binary Block BY OEM DONE Quote:
03-07-2020, 17:50 | #1595 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | LENOVO TB-8505X IMEI REPAIR DONE Lenovo TB-8504X (Tab 4 8 LTE) at USB (COM448) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: May 20 201706:15:13Jan 27 201708:00:008937.gen MDMBUILD: MPSS.JO.2.0.c1-00151-8937_GENNS_PACK-1 NV IMEI1: 863768-03-163813-1 NV IMEI2: 863768-03-165813-9 NV BTID : 7C46:85:0C2A9F NV WIFI : 9F2A:14:85467C NV SERNR: HGAF4SKB Gen.Settings Write Done: 2 Item(s) Lenovo TB-8504X (Tab 4 8 LTE) at USB (COM448) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: May 20 201706:15:13Jan 27 201708:00:008937.gen MDMBUILD: MPSS.JO.2.0.c1-00151-8937_GENNS_PACK-1 NV IMEI1: 359880-53-264125-7 NV IMEI2: 359885-62-418251-6 NV BTID : 7C46:85:0C2A9F NV WIFI : 9F2A:14:85467C NV SERNR: HGAF4SKB Lenovo TB-8504X (Tab 4 8 LTE) at USB (COM448) [DIAGS] {Restart} OFFLMODE: OK RESTART : OK |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
03-10-2020, 08:12 | #1596 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 575256 Status: Offline Thanks Meter: 34 | step Quote:
Step with picture brother share hereeeee,,, to all think this | |
03-14-2020, 14:26 | #1598 (permalink) |
Insane Poster Join Date: Sep 2011 Location: rusia
Member: 1656416 Status: Offline Thanks Meter: 23 | ZTE Blade A530 frp reset Code: Var ZTE-Blade A530 (Blade A530 LTE DS P639F10) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_PL_ZT1.bin BR ComPort: COM16 BR Asic Id: MT0699 [0000] Alias: MT6739 BR Asic Sw: 8A00 CA00 0000 0000 BR Secured: 01 [SBC] DA AgentId: SAE423F659B6662445 DA Version: MTK_AllInOne_DA_v3.3001.2018/01/31.09:11_398885. DA ProtVer: 4 PR DlagVer: 1.0 PR BootMod: preloader DA Asic Id: MT0699 [8A00 CA00 0000 0000 0000] eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14,56 GB eMMC CID : 150100514536334D420340A19071852D [QE63MB] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000040000 [262.144] 256 KB UNICAL RID: 12D35F4379E65F90DCDB69AE4D655E40 DA USBconf: high-speed PGPT Found: 39 Partition Entries SGPT Found: 39 Partition Entries Reset FRP Done in: 00:10.870 (1) DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to bs123 For This Useful Post: |
03-14-2020, 16:36 | #1599 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | Sony SOV33 pattern remove Sony SOV33 (Xperia X Perfomance LTE Dora) at USB Auto Select [S1] {Write Flash} Files to Flash: 1 USB DEV : SOMC [USB\VID_0FCE&PID_ADDE\5&35dee9d9&0&3] BL VERS : 1299-4832_S1_Boot_MSM8996_LA1.0.1_31-H BL PKTSZ: 0x00400000 BL IMEI : 358097-07-130693-4 BL ROOTS: NOT_ROOTABLE TA MODEL: SOV33 TA DEVSN: CB512ABWMF TA CDVER: 1301-6729_R21A TA SWVER: 1300-5352_35.0.D.2.25 TA FLVER: GENERIC_35.0.D.2.25 FL VERS : 1299-4832_S1_Boot_MSM8996_LA1.0.1_31-H FL PKTSZ: 0x00400000 FL IMEI : 358097-07-130693-4 FL ROOTS: NOT_ROOTABLE TA MODEL: SOV33 TA DEVSN: CB512ABWMF TA CDVER: 1301-6729_R21A TA SWVER: 1300-5352_35.0.D.2.25 TA FLVER: GENERIC_35.0.D.2.25 TA S1VER: 1299-4832 S1_Boot_MSM8996_LA1.0.1_31-H AT PLFRT: 805BC1429CFA4320A5F0449F87487505E4F3226EE75499D949 DB3C1149ABE3BA AT OTLCK: LOCKED AT OTDAT: 01000400 AT IDCOD: 409470E1 Writing File: userdata.sin File Write Done in 00:04.281 + 00:00.716 Shut Down Ok All Done in 00:18.565 |
03-16-2020, 07:54 | #1600 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Vivo Y81 User data format Quote:
The Following User Says Thank You to 4G Telecom For This Useful Post: |
03-17-2020, 09:43 | #1601 (permalink) |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Var ITEL-L5503 (A46 LTE DS F6301) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [Fdl] SC9863A_Itel_L5503_fdl Hold Vol+, Vol- and Insert Cable to Switched OFF Device FDLA: 00005000, 9EFFFE00 FDLI: SA197891715F87CB8F FDLI: SACB48AD6D14BE6448 SROM: SPRD3 FDL1: Spreadtrum Boot Block version 1.1 FDL2: Ok, 96, v2.1.2 Reset FRP Done in: 00:00.032 Restart Done, Disconnect Cable All Done in: 00:09.605 |
03-18-2020, 12:14 | #1603 (permalink) |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Gionee P5L Var GIONEE-P5L (Pioneer PL LTE DS) at USB Auto Select [MTK] {Format Flash} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM8 BR Asic Id: MT0321 [0000] Alias: MT6735 BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 04000000 DA AgentId: SABAB1470D512FC946 DA Version: MTK_AllInOne_DA_v3.3001.2019-11-06.22:49_491164. DA ProtVer: 2 PR MMC CID: 150100464531324D4207D304C86B1AB5 [FE12MB] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB eMMC CID : 150100464531324D4207D304C86B24B5 [FE12MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL RID: 892A155B5A99B164B089D00A26F004DB PMT (GPT) Found: 25 Partition Entries Erasing: LinST: 0x00D1000000 Size: 0x02D1D80000 userdata Format Flash Done in: 00:05.894 DA Shutdown Done, Disconnect Cable Var GIONEE-P5L (Pioneer PL LTE DS) at USB Auto Select [MTK] {Format Flash} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM8 BR Asic Id: MT0321 [0000] Alias: MT6735 BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 04000000 DA AgentId: SABAB1470D512FC946 DA Version: MTK_AllInOne_DA_v3.3001.2019-11-06.22:49_491164. DA ProtVer: 2 PR MMC CID: 150100464531324D4207D304C86B1AB5 [FE12MB] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB eMMC CID : 150100464531324D4207D304C86B24B5 [FE12MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL RID: 892A155B5A99B164B089D00A26F004DB PMT (GPT) Found: 25 Partition Entries Erasing: LinST: 0x0006A00000 Size: 0x0000100000 frp Format Flash Done in: 00:03.329 DA Shutdown Done, Disconnect Cable |
