04-16-2020, 12:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Samsung
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | VIVO 1804 V11 Pro Format Failed Code: Var VIVO-V11 Pro (V11 Pro LTE DS PD1814F) at Auto Select Flash Port [SAHARA] {Format Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM631) SAHARA VERS: 2.1 SAHARA HWID: 0008C0E100730004 [SDM660] SAHARA HASH: F188B3BC5198FB412FC8AB7EF8B60D245EBB705A0FC0AF387F1DB21533CC4570 SAHARA SERN: F96EED5B (4184796507) SAHARA PROG: prog_emmc_ufs_firehose_Sdm660_ddr_vivo2.elf SAHARA PRID: SA563049A70D249F05 FHPROG SZFT: 4096 FHPROG SZTT: 32768 FHPROG SPTT: 32768 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: MSM8996 FHPROG CHSN: 0xFFFFFFFE FHPROG MEMT: eMMC FHINFO Failed: 4, 30 FHPROG PART: EFI GPT FHPROG PRTY: 16 <log value="Binary build date: Sep 1 2018 @ 04:30:20"/> <log value="Chip serial num: 4294967294 (0xfffffffe)"/> <log value="Supported Functions: program configure query_auth_id_info parse_sig parse_sig_ex nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase "/> <data><nop value="ping" /></data> <log value="Binary build date: Sep 1 2018 @ 04:30:20"/> <log value="fh.attrs.Verbose is set to 0"/> <log value="Chip serial num: 4294967294 (0xfffffffe)"/> <log value="Supported Functions: program configure query_auth_id_info parse_sig parse_sig_ex nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase "/> <response value="ACK" /> <data><configure MaxPayloadSizeToTargetInBytes="49152" MemoryName="eMMC" TargetName="8x26"/></data> <log value="Supported Functions: program configure query_auth_id_info parse_sig parse_sig_ex nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase "/> <log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/> <response value="ACK" MinVersionSupported="1" MemoryName="eMMC" MaxPayloadSizeFromTargetInBytes="4096" MaxPayloadSizeToTargetInBytes="49152" MaxPayloadSizeToTargetInBytesSupported="49152" MaxXMLSizeInBytes="4096" Version="1" TargetName="MSM8996" DateTime="Sep 1 2018 - 04:30:20" /> <data><configure MaxPayloadSizeToTargetInBytes="131072" MemoryName="eMMC" TargetName="8x26"/></data> <log value="Supported Functions: program configure query_auth_id_info parse_sig parse_sig_ex nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase "/> <log value="fh.attrs.MaxPayloadSizeToTargetInBytes of 131072 > fh.channel_buffer_capacity of 49152"/> <log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/> <response value="NAK" MinVersionSupported="1" MemoryName="eMMC" MaxPayloadSizeFromTargetInBytes="4096" MaxPayloadSizeToTargetInBytes="49152" MaxPayloadSizeToTargetInBytesSupported="49152" MaxXMLSizeInBytes="4096" Version="1" TargetName="MSM8996" DateTime="Sep 1 2018 - 04:30:20" /> <data><configure ZlpAwareHost="1" SkipStorageInit="0" TargetName="MSM8996" SkipWrite="0" MaxPayloadSizeToTargetInBytes="32768" MemoryName="eMMC"/></data> <log value="Supported Functions: program configure query_auth_id_info parse_sig parse_sig_ex nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase "/> <log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/> <response value="ACK" MinVersionSupported="1" MemoryName="eMMC" MaxPayloadSizeFromTargetInBytes="4096" MaxPayloadSizeToTargetInBytes="32768" MaxPayloadSizeToTargetInBytesSupported="32768" MaxXMLSizeInBytes="4096" Version="1" TargetName="MSM8996" DateTime="Sep 1 2018 - 04:30:20" /> <data><getstorageinfo physical_partition_number="0" /></data> <log value="ERROR: SDCC Error 20 (2)"/> <log value="ERROR: Get Raw Info Failed 532"/> <log value="ERROR: Failed to get info raw 1 slot 0, partition 0, error 2"/> <log value="GetStorageInfo Raw Data failed in storage_device_get_info_raw() "/> <log value="ERROR 14: Line 1306: HANDLE_STORAGE_INFO_FAILURE"/> <response value="NAK" /> <data><read SECTOR_SIZE_IN_BYTES="512" num_partition_sectors="2" start_sector="0" physical_partition_number="0" read_back_verify="0"/></data> <response value="ACK" rawmode="true" /> Big Partition: userdata, Will be Wiped First 512 MB FHPROG WCMD Fail: -5 Format Flash Failed: userdata |
04-16-2020, 12:57 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: UK
Member: 1629133 Status: Offline Thanks Meter: 498 | Hi mate what progblem you have with your phone ? try hard reset manual and no joke with format emmc because you need to be happy is not format ! After phone dead |
