Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
Samsung Smart Watches Samsung Galaxy Gear 1 and 2 , Samsung Gear Live , Samsung Galaxy Gear Fit , Samsung Gear S |
![]() | #1 (permalink) |
Major Poster ![]() ![]() Join Date: Dec 2012 Location: This is not my familiar forum
Member: 1849224 Status: Offline Sonork: no ida Thanks Meter: 5 | Samsung Galaxy Gear SM-V700 Firmware Version Via Odin3 program - Samsung Galaxy Gear SM-V700 Stock Firmware Package. - Odin Flasher. - Samsung Galaxy Gear SM-V700 USB Drivers. Needed Tools For Updating Samsung Galaxy Gear SM-V700 Firmware: - Suitable USB cable. - A stable computer running Windows OS. Important Notice: We provide this guide for help purpose only, And we hold no responsibility at all, So keep in mind that your are doing this at your own RISK. Preparation: After downloading the needed files you should extract the zipped ones, And install the USB drivers (Restart your PC after installing). Samsung Galaxy Gear SM-V700 Firmware Update Steps: - Open Odin3.ini file using the Notepad program, You can find this file inside Odin3 folder. - Scroll down until you get this section: [ButtonOption] Bootloader=1 PDA=1 Phone=1 CSC=1 UMS/PATCH=0 - Set (UMS/PATCH) to (1) instead of (0), Then save the file. - Run Odin3.exe program. - Check these options: Re-Partition (If you have PIT file only), Auto Reboot, F.Reset Time. - Click PIT button to select: ls02.pit - Firmware files selection: Click Bootloader button to select: BOOTLOADER_V700xxxxxxx_..._REV03_user_low_ship.tar .md5 Click PDA button to select: CODE_V700xxxxxxx_..._REV03_user_low_ship.tar.md5 Click CSC button to select: CSC_Oxx_V700Oxxxxxx_..._REV03_user_low_ship.tar.md 5 Click UMS button to select: GANG_V700xxxxxxx_..._REV03_user_low_ship.tar.md5 - Entering the Download Mode: Press the Power key for 7 seconds and then Press the Power Key 1 more time after display changed, Select the Download mode ( Press and release the Power key for 0.5 sec to move and press it for 1.6 sec to select). - Insert the Smartwatch into the charging-dock And lock it. - Use the USB cable to connect your device to the computer, Don't use any USB-HUB for connecting, And use only main USB slots. - Wait until Windows detects the connected device and installs its suitable USB drivers. - In case everything is OK, Then Odin program will detect your connected device (0:[COMxx]). - Click on Start button. - Odin program will start installing the new firmware files into your device, So wait until the device reboots. - If the update was successfully done, Then you will notice PASS! Word at Odin program. - Disconnect the USB cable. - Wait for the Smartwatch to be fully on. - Now you can customize your device after installing the new firmware version. Notice: When you get one big file inside the firmware package, Then it should be selected as a PDA file only, And do not check Re-Partition option or use PIT file at all. |
