Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
02-06-2014, 17:01 | #4051 (permalink) | |
No Life Poster Join Date: Feb 2012 Location: Ukraine. Украина Age: 42
Member: 1720170 Status: Offline Thanks Meter: 6,341 | Quote:
- Search in the list SRO name, starts with 'X' letter - Click in SRO NAME and fill it ( 8 or 12 digits ) - Write in SRO field for example XM66NA40 | |
The Following User Says Thank You to vorden For This Useful Post: |
02-06-2014, 17:33 | #4054 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2122711 Status: Offline Thanks Meter: 0 | Am I going to turn on the phone with a sim or not? Cause every time I type *#3228# it shows image mapping list and I can't even click any on that list. Thank you for your response sir. |
02-06-2014, 17:41 | #4056 (permalink) | |
Phone Selected : Alc. OT-5020 Phone ID : 5020W-2DALUS1 Phone Imei : 013584001464369 Nck Code : 14462017 Spck Code : 15509711 Nsck Code : 39824914 Cpck Code : 08985260 Cck Code : 41207811 Pck Code : 13590281 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... ---- IMPORTANT ---- If phone not accept NCK, sometimes must be resetted A) Press VOLUME UP + POWER ON (at same time) B) Press KEY # + POWER ON (at same time) C) Press VOLUME DOWN + POWER ON, select CLEAR EMMC and press HOME If the phone requests unlock code Insert the original sim Power ON Type ###765*08# Select Network Unlock and enter Nck | |
02-06-2014, 17:46 | #4057 (permalink) | |
Phone Selected : Alc. OT-903D Phone ID : XAA0ST00 Phone Imei : 865333011932398 Nck Code : 27307402 Spck Code : 36786289 Nsck Code : 37202561 Cpck Code : 36382907 Cck Code : 28246539 Pck Code : 32021244 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... ---- IMPORTANT ---- If phone not accept NCK, sometimes must be resetted A) Press VOLUME UP + POWER ON (at same time) B) Press KEY # + POWER ON (at same time) C) Press VOLUME DOWN + POWER ON, select CLEAR EMMC and press HOME If the phone requests unlock code Insert the original sim Power ON Type ###765*08# Select Network Unlock and enter Nck | |
02-06-2014, 17:52 | #4058 (permalink) | |
Junior Member Join Date: Dec 2007
Member: 666793 Status: Offline Thanks Meter: 1 | Quote:
but still wrong codes. MICROBOX calculate all identical codes and all codes is wrong. Another solution ? Please! | |
02-06-2014, 18:56 | #4065 (permalink) | |
860551020498243 NCK 41025762 Friend! Sorry But is Not allowed (Forum Rules) Reply with "Thanks, Thank you etc" If Any member help you press Thanks Button, this is for all members | |
