Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
09-18-2002, 01:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2002 Location: Heaven Age: 46
Member: 14579 Status: Offline Thanks Meter: 0 | Sagem MW3026 UNLOCK???? Here is the log : Started at: Wed Sep 18 03:33:13 2002 [Model:SAGEM][VerF4,5F: 151001 1922/234511267109][IMEI:33230435509608-7][ID:00][1:260024ffffffff2200000000000000220000000000000022 000000000000002200000000000000][2:0a083a2303345590067848][3:058fb665e220] Thanking you beforehand for your kind help and replies. With Best Regards Mehvishal2 [email protected] |
09-18-2002, 21:07 | #2 (permalink) |
Member: 14579 Status: Offline Thanks Meter: 0 | Please help with MW3026!!! Sagem MW3026 UNLOCK???? Please can anyone help to calculate one UNLOCK code for MW3026 please!!! Here is the log : Started at: Wed Sep 18 03:33:13 2002 [Model:SAGEM][VerF4,5F: 151001 1922/234511267109][IMEI:33230435509608- 7][ID:00][1:260024ffffffff220000000000000022000000 0000000022000000000000002200000000000000][2:0a083a 2303345590067848][3:058fb665e220] Thanking you beforehand for your kind help and replies. With Best Regards Mehvishal2 [email protected] |
09-29-2002, 19:47 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @Chris922 Not all DF4,5F, not all, believe me!!! For example you can find ID for this 2 logs: [Model:SAGEM][VerF4,5F: 151001 1922/310421672195][IMEI:33230435351600-3][ID:00][1:260024ffffffff2200000000000000220000000000000022 000000000000002200000000000000][2:0a083a2303343515063048][3:055ad39c4c20] [Model:SAGEM][VerF4,5F: 151001 1922/102311925467][IMEI:33230435332383-0][ID:00][1:260024ffffffff2200000000000000220000000000000022 000000000000002200000000000000][2:0a083a2303343523830348][3:05e0dffb5220] Yes, code calculating for DF4,5F is very sample, but hrco code or ID is wrong. |
09-29-2002, 21:26 | #7 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Georgia Tbilisi Age: 47
Member: 12524 Status: Offline Thanks Meter: 3 | hi latigido how are you man for you 2 log code IMEI: 33230435351600-3 Unl: 15393164-93 - [ F251 HEX: 5BC01B0D ] IMEI: 33230435332383-0 Unl: 37868746-37 - [ F251 HEX: E1B71F0D ] ))) corect? |
09-29-2002, 22:34 | #10 (permalink) |
Member: 12524 Status: Offline Thanks Meter: 3 | friend i have 1 log i not calculate id or unlock code please you have calculator for thise version? Started at: Fri Sep 27 19:02:56 2002 [Model:SAGEM][VerH4,6J: 051201 1740/217036105489][IMEI:35072835030555-5][ID:00][1:260024ffffffff2100000000000000210000000000000021 000000000000002100000000000000][2:0a083a0527380503555548][3:05de6be1b620] |
09-30-2002, 02:41 | #11 (permalink) |
No Life Poster Join Date: Sep 2002 Location: home
Member: 15506 Status: Offline Thanks Meter: 3 | I have same problems giorgi2002 this your phone is hash 21......I can't calculating id ....I have same problems whit my phones..... I try all solution..... If you finde something.........call me [email protected] |
09-30-2002, 08:39 | #12 (permalink) |
No Life Poster Join Date: Mar 2002
Member: 10175 Status: Offline Thanks Meter: 0 | latigido: OK Then i correct me :-) They all have 03317X IDs. No problem, to find (as you already told) 083A23033435150630 -> 033170FF37F5 and 083A23033435238303 -> 033170FFBB6F But you have to know the lock-level (now i call the uncrypted databyte of 251 lock level) of the phone. In this case its 41. Thats easy. But as i know, there are more than 41,01 -> locked 00 -> never locked / unlocked 40 -> unlocked And if you don't know these, it might be hard to find the (correct) ID only from field 191/251 |
09-30-2002, 19:27 | #13 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | Chris922. My experience and knowledge proved- not need to know in advance lock level for Sagem with 03317xxxxxxx ID. However you can see in Sagem phones only(?) 4 different lock level. |
need help Sagem mw3026-unlock kode? | Lugo | Phone Unlocking Codes & Maps | 3 | 03-26-2003 18:12 |
Sagem MW3026 unlock code? | pavlin | Phone Unlocking Codes & Maps | 0 | 03-12-2003 23:40 |
Sagem MW3026 Unlock | Bacila | Phone Unlocking Codes & Maps | 5 | 03-12-2003 18:32 |
Sagem MW3026 unlock | Jack The Nipper | Infineon C16X M51 & ARM7 M52 BASED | 0 | 02-03-2003 23:06 |
Sagem MW3026 ..... unlock code ... HELP! | Kot | Phone Unlocking Codes & Maps | 2 | 10-15-2002 09:05 |
