Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
05-15-2010, 10:19 | #63378 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9419 Status: Offline Thanks Meter: 1,030 | ------------------------------ 353679032475711 Flash: 45576395 Unlock: 38209002 ------------------------------ 1. Remove the SIM card and connect the USB Modem to the PC 2. Run the HUAWEI_MODEM_Code_Write 3. click - Please Select Com Port 4. click detect and slect your modem from list then click accept 5. click Unlock Modem and enter your 8 digit unlock code 6. click ok HUAWEI_MODEM_Code_Write Best regards, Edward1 |
05-15-2010, 10:25 | #63380 (permalink) |
Junior Member Join Date: May 2010
Member: 1303659 Status: Offline Thanks Meter: 0 | Please help unlock these modem: Model E220 IMEI: 354137022650008 Model E 160 IMEI: 353871029244982 to [email protected] Thanks in advance |
05-15-2010, 10:26 | #63381 (permalink) |
Member: 9419 Status: Offline Thanks Meter: 1,030 | ------------------------------ 351596031880729 model E160 Flash: 39904686 Unlock: 41231066 ------------------------------ 1. Remove the SIM card and connect the USB Modem to the PC 2. Run the HUAWEI_MODEM_Code_Write 3. click - Please Select Com Port 4. click detect and slect your modem from list then click accept 5. click Unlock Modem and enter your 8 digit unlock code 6. click ok HUAWEI_MODEM_Code_Write Best regards, Edward1 |
The Following User Says Thank You to Edward1 For This Useful Post: |
05-15-2010, 10:27 | #63382 (permalink) | |
Member: 9419 Status: Offline Thanks Meter: 1,030 | Quote:
huawei E220 is Not supported by IMEI calculator, any calculated codes would be wrong E220_Unlock Best regards, Edward1 | |
05-15-2010, 10:29 | #63383 (permalink) | |
353871029244982 model E160 Flash: 39805110 Unlock: 49299894 ------------------------------ 1. Remove the SIM card and connect the USB Modem to the PC 2. Run the HUAWEI_MODEM_Code_Write 3. click - Please Select Com Port 4. click detect and slect your modem from list then click accept 5. click Unlock Modem and enter your 8 digit unlock code 6. click ok HUAWEI_MODEM_Code_Write Best regards, Edward1 | |
05-15-2010, 10:47 | #63389 (permalink) |
Member: 9419 Status: Offline Thanks Meter: 1,030 | huawei E220 is Not supported by IMEI calculator, any calculated codes would be wrong E220_Unlock Best regards, Edward1 |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f88/huawei-unlocking-codes-request-only-here-781410/ | ||||
Posted By | For | Type | Date | |
Unlock Idea net setter Eg162G | This thread | Trackback: | 04-20-2011 20:54 |
ZTE MDM Unlocking codes Request [ONLY HERE] | DanilowAlexandr | Phone Unlocking Codes & Maps | 11 | 03-19-2010 18:48 |
Huawei MDM Unlocking codes Request [ONLY HERE] | samalik | Infinity-Box | 5 | 02-10-2010 16:23 |
