Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
12-02-2009, 04:29 | #12602 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Manila, Philippines
Member: 10541 Status: Offline Thanks Meter: 8 | Found Phone, Phone Info: - Manufacturer :huawei - Model :E160X - Revision :11.608.05.00.00 - Phone IMEI :355856025424132 Send Unlock Command... ERROR mvr |
12-02-2009, 06:41 | #12610 (permalink) |
Freak Poster Join Date: Apr 2007 Location: ISLA SA MACTAN
Member: 490909 Status: Offline Thanks Meter: 122 | Hello, Please could you send me unlock code and flash code for a Huawei E160G IMEI: 354300028703060 Thanks you! Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35430002870306 Code: 64004915 Done! ================================================== ========= Huawei E1552 IMEI# 353143034991829 Unlocking code pls. thanks Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35314303499182 Code: 37827718 Done! ================================================== ========= Huawei e156c IMEI# 358641020007943 unlocking code pls. Thanks Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35864102000794 Code: 54199937 Done! ================================================== ========= Hello))) Model : Huawei E1550 IMEI : 357123033505701 Firmware : 11.608.12.00.143 Thanks you! Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35712303350570 Code: 47703263 Done! ================================================== ========= |
12-02-2009, 06:42 | #12611 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1163154 Status: Offline Thanks Meter: 1 | Help Me :((( Please unlock my Huawei E1550 usb modem: Imei: 357123030266596 Thank you very much in advance! |
The Following User Says Thank You to os400Linux For This Useful Post: |
12-02-2009, 06:53 | #12612 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1146314 Status: Offline Sonork: brayn7 Thanks Meter: 1 | Good day bro.. Kindly please unlock my usb modem.. Model: E1552 IMEI: 353143032640428 Thanks.. |
The Following User Says Thank You to brayn7 For This Useful Post: |
12-02-2009, 07:03 | #12614 (permalink) |
Member: 490909 Status: Offline Thanks Meter: 122 | Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35712303026659 Code: 56143045 Done! ================================================== ========= Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35314303264042 Code: 50173830 Done! ================================================== ========= Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35712303856494 Code: 63176070 Done! ================================================== ========= |
The Following User Says Thank You to tingardz_vrc For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f88/huawei-unlocking-codes-request-only-here-781410/ | ||||
Posted By | For | Type | Date | |
Unlock Idea net setter Eg162G | This thread | Trackback: | 04-20-2011 20:54 |
ZTE MDM Unlocking codes Request [ONLY HERE] | DanilowAlexandr | Phone Unlocking Codes & Maps | 11 | 03-19-2010 18:48 |
Huawei MDM Unlocking codes Request [ONLY HERE] | samalik | Infinity-Box | 5 | 02-10-2010 16:23 |
