Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
![]() | #4292 (permalink) | |
Moderator ![]() Join Date: Mar 2006 Location: Morocco
Member: 247448 Status: Offline Sonork: 100.108039 Thanks Meter: 2,099 ![]() | Quote:
Siemens CL-75 - IMEI : 356328002793284 Unlock Codes: NCKKN: **00012*00148168# NCKKN 2: **00013*61528416# NSCKN: **00022*86550161# NSCKN 2: **00023*03314640# SPCKS: **00032*00108968# SPCKS 2: **00033*61188496# CKCCK: **00042*88530161# CKCCK 2: **00043*03316640# PCKKP: **00052*08188168# PCKKP 2: **00053*61528496# good luck........ | |
![]() | #4295 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005 Age: 47
Member: 175544 Status: Offline Thanks Meter: 198 | Codes for imei 356328003627853, model Siemens CL75 Unlocking codes: Code for NCKKN is : **00012*61408009# Code for NSCKN is : **00022*69280609# Code for SPCKS is : **00032*61468809# Code for CKCCK is : **00042*63200609# Code for PCKKP is : **00052*61468009# Code for XXXXX is : **00062*63200609# Code for XXXXX is : **00072*69280609# Repair codes: Code for NCKKN2 is : **00013*60938506# Code for NSCKN2 is : **00023*60310366# Code for SPCKS2 is : **00033*60598506# Code for CKCCK2 is : **00043*60310306# Code for PCKKP2 is : **00053*60938586# Code for XXXXX2 is : **00063*60110306# Code for XXXXX2 is : **00073*60116366# New Algo Codes Unlocking codes: Code for NCKKN is : **00012*6140800929446423# Code for NSCKN is : **00022*6928060929462223# Code for SPCKS is : **00032*6146880929462223# Code for CKCCK is : **00042*6320060923422223# Code for PCKKP is : **00052*6146800929466423# Code for XXXXX is : **00062*6320060923422223# Code for XXXXX is : **00072*6928060929462223# Repair codes: Code for NCKKN is : **00013*6093850682732306# Code for NSCKN is : **00023*6031036682112306# Code for SPCKS is : **00033*6059850682518306# Code for CKCCK is : **00043*6031030682112346# Code for PCKKP is : **00053*6093858682738306# Code for XXXXX is : **00063*6011030682112346# Code for XXXXX is : **00073*6011636682118306# |
![]() | #4296 (permalink) | |
Junior Member Join Date: May 2006
Member: 271926 Status: Offline Thanks Meter: 0 | Quote:
Are the codes the same for c75 and cl75 ??? Mine is a c75 , you calculated for cl75 or does it make no difference ??? thanks | |
![]() | #4298 (permalink) | |
Siemens CL-75 - IMEI : 356328007958015 Unlock Codes: NCKKN: **00012*78109629# NCKKN 2: **00013*76499216# NSCKN: **00022*65550160# NSCKN 2: **00023*03004780# SPCKS: **00032*78109829# SPCKS 2: **00033*76499276# CKCCK: **00042*65510160# CKCCK 2: **00043*03006780# PCKKP: **00052*76189629# PCKKP 2: **00053*76499276# | |
![]() | #4299 (permalink) | |
Junior Member Join Date: May 2007
Member: 505492 Status: Offline Thanks Meter: 0 | Quote:
Tnx it works you make me very happy ![]() ![]() | |
![]() | #4301 (permalink) |
Member: 505576 Status: Offline Thanks Meter: 0 | Apologies to be a pai but can someone give me the code I need to unlock a SIM MEP LOCK FAILED message on a siemens poppy cl75 phone. I see lists of codes above but have no idea how / when to input them or which one to use. My IMEI is: 356328005993170 Many thanks and apologies again for being a bit non-techie! xx |
![]() | #4302 (permalink) | |
Siemens CL-75 - IMEI : 356328005993170 Unlock Codes: NCKKN: **00012*16361949# NCKKN 2: **00013*73757368# NSCKN: **00022*01562175# NSCKN 2: **00023*41730756# SPCKS: **00032*13397749# SPCKS 2: **00033*73637398# CKCCK: **00042*01562175# CKCCK 2: **00043*41730776# PCKKP: **00052*10381949# PCKKP 2: **00053*73757388# enter the first code an test if not unlocked try the second ....... | |
![]() | #4303 (permalink) |
Member: 505576 Status: Offline Thanks Meter: 0 | THANK YOU!!!!!!!!!!!! I really cannot thank you enough. I would like to be able to offer something back to this forum but sadly lack in any kind of techie skills! I am so grateful, I really am. B xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxx |
![]() | #4304 (permalink) |
Member: 506121 Status: Offline Thanks Meter: 0 | hi im new to this forum, im trying to unlock my mums cl75 poppy phone so she can use it on her orange sim card.its locked to vergin at the mo. the IMEI is:- 356328007334076 thank you. adam |
![]() | #4305 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 ![]() | Quote:
Unlocking codes: Code for NCKKN is : **00012*16361983# Code for NSCKN is : **00022*12581983# Code for SPCKS is : **00032*13397983# Code for CKCCK is : **00042*14581983# Code for PCKKP is : **00052*12381983# Code for XXXXX is : **00062*14581983# Code for XXXXX is : **00072*14381983# Repair codes: Code for NCKKN2 is : **00013*75917378# Code for NSCKN2 is : **00023*75411598# Code for SPCKS2 is : **00033*75877398# Code for CKCCK2 is : **00043*75411598# Code for PCKKP2 is : **00053*75917398# Code for XXXXX2 is : **00063*75411598# Code for XXXXX2 is : **00073*75417298# New Algo Codes Unlocking codes: Code for NCKKN is : **00012*1636198396769121# Code for NSCKN is : **00022*1258198390185921# Code for SPCKS is : **00032*1339798393779521# Code for CKCCK is : **00042*1458198390185921# Code for PCKKP is : **00052*1238198390749121# Code for XXXXX is : **00062*1458198390183921# Code for XXXXX is : **00072*1438198390783921# Repair codes: Code for NCKKN is : **00013*7591737839957378# Code for NSCKN is : **00023*7541159839253318# Code for SPCKS is : **00033*7587739839853378# Code for CKCCK is : **00043*7541159839253318# Code for PCKKP is : **00053*7591739839953378# Code for XXXXX is : **00063*7541159839053318# Code for XXXXX is : **00073*7541729839053218# | |
AEG / Telital, MAXON & Vitel Unlocking codes. [ONLY HERE] | DrMobile | Phone Unlocking Codes & Maps | 890 | 07-01-2020 07:50 |
***Free ORANGE FRANCE Unlock codes, only here!!! only TODAY*** | DEBLOQUETOUT | Phone Unlocking Codes & Maps | 12 | 08-27-2005 19:15 |
***Free Sagem Unlock codes, only here*** | Kole64 | Phone Unlocking Codes & Maps | 4453 | 03-05-2005 22:36 |
