BST / BSTPro Dongle BestSmartTools Official Support Section |
11-18-2014, 14:07 | #2 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, Use This & Finish Your Work .. CF-Root Download Quote:
Regards, _________ GsmBest Team | |
The Following User Says Thank You to ..::CHAIN::.. For This Useful Post: |
11-18-2014, 19:09 | #4 (permalink) |
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, If Not Success Then Try To Flash With Pre Rooted Firmware. Search On Google Then Try .... Regards, --------------- GsmBest Team |
11-18-2014, 19:13 | #5 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | 1. Odin 3.09 2. Philz recovery 6.26.6 (.tar.md5 required) from http://goo.im/devs/philz_touch/CWM_A...-n7100.tar.md5 3. Update SuperSu v2 from here SuperSU Download Procedure 1.Download and open Odin v3.09 2.Load your downloaded recovery onto the PDA/AP button on Odin 3.Make sure you dont mess with anything else on Odin. 4.Now click Start and your recovery will be flashed in under 10 seconds. Now boot into recovery and flash the update superSu v1.94 zip. 5. Now you can reboot your phone. Done.Your device is rooted now. |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
11-19-2014, 07:54 | #6 (permalink) |
No Life Poster Join Date: Feb 2010 Location: pakistan(Timergara) Age: 37
Member: 1224733 Status: Offline Thanks Meter: 158 | thanks team,after update seper user succesfully repair imei note 2 n7100 4.4.2 Fw.Ver : BstKey V3.18 Serial : XXXX-XXXX-XXXX-XXXX Active User: zulfiqar PL2303 : 3.4.48.272 2013-02-05 (OK) Best Smart Tools, Load OK. Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-N7100 Hardware: SMDK4X12 Mode: normal Prepare environment ... Bypass MSL ... Detect new security ... Backup EFS ... D:\BST\backup\samsung\efs\GT-N7100\EFS_samsung_GT-N7100_004999010640000_2014-11-19_11.36.04.efs ok Update device ... Reboot device to NORMAL mode ... Wait device ready ... Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device |
