08-28-2015, 20:18 | #4 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | Hi, custumer unlocks it's Kyocera C6530n in another place. I don't like not to have services that are aviable. How can I unlock this set? This phone DOES NOT have the "device Unlock" aplication and it says clearly in the service you point "device must have Device Unlock aplication" Could you please help me? Here's what the Metro Pcs android service says: "Once the unlock request is processed, customer needs to: Make sure you have an active data connection via 3G/4G/LTE or Wi-Fi. From the Application list, tap Device Unlock. (Note: The application may be located in the MetroPCS folder.) Tap Continue. Choose the Permanent Unlock type: If successful, restart the device to apply the settings. Note: If you do not restart the device, you will have a persistent alert in the notification tray." "WARNING: It is very important to mention that the customer has to have data when attempting to perform the unlock, either 3G, 4G or wi-fi but data on the phone. If there is no data the unlock will be unsuccessful, once a device has been whitelisted we will not be responsible for unsuccessful unlocks. If customer has changed the original software or IMEI we will not be responsible for the app not to work (Do not install custom firmware like Avatar or Cyanogen before unlock your phone). If customer cannot find the app on its phone he can easily go to applications and make it visible but a Hard Reset will always bring the app back to the phone." |
