01-13-2022, 15:42 | #61 (permalink) |
Junior Member Join Date: Apr 2017 Location: algerie
Member: 2709310 Status: Offline Sonork: 0123346 Thanks Meter: 2 | |
01-29-2022, 10:19 | #63 (permalink) |
Insane Poster Join Date: Apr 2014
Member: 2171504 Status: Offline Thanks Meter: 51 | Superb update for Xiamoi phone redmi 9a dual imei repair one click Chimera Mobile Phone Utility version: 31.02.1617 @ 2022-01-29 Patch IMEI Change to bootrom mode ADB interface detected. Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! bootrom interface detected. Initializing... Unlocking bootloader... All of your user data might be erased from the device! Reading data from the phone... Reading data from the phone... Original IMEI1: xxxxxxxxxxxxxxx Original IMEI2: xxxxxxxxxxxxxxx Writing new IMEI(s) Waiting for the phone to restart... Be aware that the effect of this procedure lasts only until the system is unchanged. Doing a firmware update or an OTA update likely causes the phone to restore to its original state. Finished at local time: [01.29.22 14:13:07] WorkID: 167645854 |
01-29-2022, 10:20 | #64 (permalink) |
Member: 2171504 Status: Offline Thanks Meter: 51 | Redmi 9a dual imei repaired by one click Superb update for Xiamoi phone redmi 9a dual imei repair one click Chimera Mobile Phone Utility version: 31.02.1617 @ 2022-01-29 Patch IMEI Change to bootrom mode ADB interface detected. Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! bootrom interface detected. Initializing... Unlocking bootloader... All of your user data might be erased from the device! Reading data from the phone... Reading data from the phone... Original IMEI1: xxxxxxxxxxxxxxx Original IMEI2: xxxxxxxxxxxxxxx Writing new IMEI(s) Waiting for the phone to restart... Be aware that the effect of this procedure lasts only until the system is unchanged. Doing a firmware update or an OTA update likely causes the phone to restore to its original state. Finished at local time: [01.29.22 14:13:07] WorkID: 167645854 |
The Following User Says Thank You to rajpootkhoaf For This Useful Post: |
01-31-2022, 12:41 | #65 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,781 | reply Dear User, Thank you for the report, good work from you. Best regards Sab Chimera team Quote:
