02-25-2019, 18:58 | #496 (permalink) | |
Freak Poster Join Date: Jan 2012 Location: Kilis
Member: 1715473 Status: Offline Thanks Meter: 105 | Quote:
02-26-2019, 04:09 | #497 (permalink) |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | G935F android 8 Binary 4 can Patch Cert if yes please reply here. |
The Following User Says Thank You to amar181 For This Useful Post: |
02-26-2019, 14:49 | #498 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Hi, I found lot of successfully patch cert process for example with the follow firmware: Android Version: 8.0.0 PDA Version: G935FXXS4ESAF Phone Version: G935FXXU4ESAE CSC Version: G935FOJV4ESAH PDA Version: G935FXXS4ESBA Phone Version: G935FXXU4ASA1 CSC Version: G935FUUB4ESBA Best regards Nicole |
02-26-2019, 14:56 | #499 (permalink) | |
Freak Poster Join Date: Apr 2017 Location: argentina
Member: 2707459 Status: Offline Thanks Meter: 31 | Quote:
02-27-2019, 17:17 | #503 (permalink) |
Freak Poster Join Date: May 2014 Location: italy
Member: 2188821 Status: Offline Sonork: TECHNOLOGYFORLIFE Thanks Meter: 60 | g955f 8.0 u4 done after patch imei status ok Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: DBT Country Code: Germany Timezone: Europe/Rome Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Nov 30 20:06:47 KST 2018 PDA Version: G955FXXU4CRKG [november 2018, revG] Phone Version: G955FXXU4CRK1 [november 2018, rev1] CSC Version: G955FOXM4CRK1 [november 2018, rev1] Product Code: DBT HIDSw Version: G955FXXU4CRKG/G955FOXM4CRK1/G955FXXU4CRK1/G955FXXU4CRKG Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8K40xxxx Imei: 35538101xxxxxxx Unique Number: CE12171CDD766A3A03 Connections: AT,MTP Battery Status: 4.19V (86%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-11-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Checking modem. Checking root. The knox is still valid. Because of the root, the warranty will void. Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image-based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G955F, Region: EUR, Provider: OPEN, PDA: G955FXXU4CRKG Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling Knox. Be patient! Do NOT disconnect the phone! Knox disabled. Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server. Be patient! Do NOT disconnect the phone! Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.27.19 17:12:57] WorkID: 53597012 |
The Following User Says Thank You to niko5610 For This Useful Post: |
02-27-2019, 18:50 | #504 (permalink) |
Freak Poster Join Date: Feb 2016 Location: san jose
Member: 2534813 Status: Offline Thanks Meter: 18 | modem downgrade no posible, no exist combination bit 5 The current modem (J701MTVJU5BRH4) is sensitive to the knox state. The warranty is void (knox is 1), so the patchcert cannot work. Try an older modem. |
02-27-2019, 19:01 | #505 (permalink) |
Junior Member Join Date: Nov 2013 Location: Addis Ababa
Member: 2074265 Status: Offline Thanks Meter: 1 | hello there i used this tool to repair imei of sm-n960f but the imei status shows NG the phone show emergence calls only and there is no support for patch cert so can any one please help me by sending a valid backup cert for sm-n960f cause im stuck with no solution Thanks |
02-27-2019, 21:43 | #506 (permalink) | |
Major Poster Join Date: Dec 2014 Location: Nigeria, kano state
Member: 2307002 Status: Offline Thanks Meter: 2 | Quote:
