02-20-2019, 06:59 | #466 (permalink) |
Freak Poster Join Date: Dec 2008 Location: argentina
Member: 930014 Status: Offline Sonork: 1685379:ktre Thanks Meter: 84 | (debes salir de rmm state prenormal para poder rootear con Magisk-v17.1 desde TWRP-3.2.3-For-Galaxy-J7-Prime y ahi recién podrás parchear el imei....) Last edited by ktre; 02-20-2019 at 07:06. |
02-20-2019, 11:44 | #468 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Hi, please send us some work id and we can check your case. Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
02-20-2019, 12:31 | #469 (permalink) |
Junior Member Join Date: Jan 2017 Location: karachi pakistan
Member: 2669342 Status: Offline Thanks Meter: 6 | samsung j400f Patch certificate [ error] Could not read the boot image for analysis Chimera Mobile Phone Utility version: 20.24.1610 @ 2019-02-19 Printing phone history Patch Certificate 2/17/2019 12:48:14 PM Repair IMEI 2/17/2019 12:45:08 PM Patch Certificate 2/17/2019 12:26:13 PM Patch Certificate 2/17/2019 12:22:52 PM Patch Certificate 2/17/2019 12:22:14 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J400F Sales Code: XME Country Code: MALAYSIA Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Jul 31 18:00:50 KST 2018 PDA Version: J400FXXU2ARH1 [august 2018, rev1] Phone Version: J400FXXU2ARG7 [july 2018, rev7] CSC Version: J400FOLM2ARG2 [july 2018, rev2] Product Code: XME HIDSw Version: J400FXXU2ARH1/J400FOLM2ARG2/J400FXXU2ARG7/J400FXXU2ARH1 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RV8K7105C7N Imei: 123456789123456 Unique Number: CQE001D49D04C65 Connections: AT,MTP Battery Status: 3.96V (46%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-07-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. Checking boot image. Be patient! Do NOT disconnect the phone! Could not read the boot image for analysis. Finished at local time: [02.19.19 13:22:37] WorkID: 52933097 |
02-20-2019, 13:02 | #470 (permalink) | |
No Life Poster Join Date: Feb 2015 Location: IRAN-TABRIIZ
Member: 2339474 Status: Offline Sonork: 100.1662352 Thanks Meter: 332 | Quote:
dont use eft boot or other only magisk root working for this phone and j600xx but patch cert ok but emergency call only i hope chimera working for root problems | |
02-20-2019, 13:50 | #471 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | Chimera Mobile Phone Utility version: 20.28.1515 @ 2019-02-20 Printing phone history Info 2/20/2019 9:57:16 AM Patch Certificate 2/20/2019 9:08:28 AM Patch Certificate 2/20/2019 8:48:02 AM Info 2/20/2019 8:46:08 AM Repair IMEI 2/20/2019 8:43:31 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: ECT Country Code: Nigeria Timezone: Africa/Lagos Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Sep 11 11:17:24 KST 2018 PDA Version: G950FXXU4CRI5 [september 2018, rev5] Phone Version: G950NKOU2CRF2 [june 2018, rev2] CSC Version: G950FOXM4CRI5 [september 2018, rev5] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R39JC00ZMD Imei: 3550900FFFFF Battery Status: 3.74V (12%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-09-01 Data Encryption State: unsupported Preparing... Checking current patchcert. Checking modem. Checking root. Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server. Be patient! Do NOT disconnect the phone! Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.20.19 12:52:04] WorkID: 53036522 |
02-20-2019, 14:14 | #472 (permalink) |
02-20-2019, 23:52 | #475 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Kilis
Member: 1715473 Status: Offline Thanks Meter: 105 | yes there is an open bug in the program. Today I said SM-J330F unsupported model. but the device is not root. server-driven errors with great probability. sometimes even the models you have done are given an error. the same process must be repeated a few more times. Try the same low firmware with the Boot version as possible. In new model devices, the network may be late. it finds almost 5 minutes. restart the software in case of not recognizing the device and not performing the operation. I found a way this way today. some models have a knox 1 error. Eng modem attempts will be successful. |
The Following User Says Thank You to nbrios For This Useful Post: |
02-21-2019, 02:07 | #477 (permalink) |
Freak Poster Join Date: Oct 2016 Location: United Republic of Tanzania
Member: 2639338 Status: Offline Thanks Meter: 133 | No Need To Change Firmware, Just Change Sim Card Slots. In My Case On My G950F I Have Two Sim Cards Which Are TIGO And TTCL whereby Whenever I Restart My Phone, One Sim Shall Lose Network So What I Do Is Changing The Sim Cards From Sim1 To Sim2 And Sim2 To Sim1. Since Tigo Is My Favorite Sim And I Want it To Remain in Slot 1 So I Will Change Them Again And Network Will Be Ok On Both Slots. Whenever U Restart The Phone U Shall Lose Network So Avoid Restarting And When Hapen Just Do The Trick |
02-21-2019, 10:20 | #479 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
How can see from you log for FW used: Quote:
Original FW ECT code from Nigeria not is out with U2 modem, can explain please? | ||
02-21-2019, 20:27 | #480 (permalink) |
Freak Poster Join Date: May 2014 Location: italy
Member: 2188821 Status: Offline Sonork: TECHNOLOGYFORLIFE Thanks Meter: 60 | please chimera add eng root a600fn twrp + magisk not work imei status NG Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A600FN Sales Code: OMN Country Code: ITALY Timezone: Europe/Rome Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Oct 4 13:26:53 KST 2018 PDA Version: A600FNXXS3ARJ3 [october 2018, rev3] Phone Version: A600FNXXU3ARJ3 [october 2018, rev3] CSC Version: A600FNOVF3ARH3 [august 2018, rev3] Product Code: OMN HIDSw Version: A600FNXXS3ARJ3/A600FNOVF3ARH3/A600FNXXU3ARJ3/A600FNXXS3ARJ3 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8KB0BX3WE Imei: 358875080xxxxxx Unique Number: CBJ0037054ECD95 Connections: AT,MTP Battery Status: 3.86V (41%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-10-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. Checking boot image. Be patient! Do NOT disconnect the phone! Selinux could cause problems. If the patchcert does not work, try another root solution. Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server. Be patient! Do NOT disconnect the phone! Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.21.19 20:14:14] WorkID: 53163753 |
