10-20-2020, 09:34 | #1111 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Anyway thanks for update. When can Add Qualcomm Imei Repair + Patch like A705F? |
The Following User Says Thank You to allumts For This Useful Post: |
10-20-2020, 09:47 | #1112 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Gela
Member: 293758 Status: Offline Thanks Meter: 39 | Model: SM-J600FN Carrier ID: ITV Sales Code: ITV Country Code: ITALY Timezone: Europe/Rome Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jun 11 16:01:45 KST 2020 PDA Version: J600FNXXU8CTF5 [june 2020, rev5] Phone Version: J600FXXU8CTF5 [june 2020, rev5] CSC Version: J600FNOXM8CTF5 [june 2020, rev5] Board Platform: UNIVERSAL7870 Modem Platform: SHANNON315 Serial Number: RF8K60NHQTV Imei: 357063093513080 Imei2: 357064094513087 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: ef9d077c:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [10.20.20 10:47:03] WorkID: 111963854 Not supported last firmware!!! Why? |
10-20-2020, 11:45 | #1115 (permalink) |
Freak Poster Join Date: Oct 2009 Location: IND TO RSA.
Member: 1143337 Status: Offline Thanks Meter: 104 | Connecting to device.....OK Reading device info.....OK Baseband Version: A505FXXU5BTIC,A505FXXU5BTIC Serial Number: R58M67W8KPK Device Arch: exynos9610 Device bootloader: A505FDDU5BTJ2 Device selinux: enforcing Device warranty bit: 1 Device Firmware: A505FDDU5BTJ2 Android version: 10 Device SDK: 29 Device data encryption: encrypted Firmware Country: SOUTH AFRICA Device Hardware: exynos9610 Device CPU: arm64-v8a Device Factory: samsung Device Model: SM-A505F Device IMEI: 355396049783833 Root status.....Rooted { 3.19:EFTSU } Rebooting to recovery.....OK Operation {Reboot} ID: ADD697DD9E0E3F27 Elapsed time 00:00 -- Version 3.4.5 Chimera Mobile Phone Utility version: 26.37.0928 @ 2020-10-20 Printing phone history Patch Certificate 10/20/2020 10:38 AM Repair IMEI 10/20/2020 9:48 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Carrier ID: XFA Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Oct 1 11:23:35 KST 2020 PDA Version: A505FDDU5BTJ2 [october 2020, rev2] Phone Version: A505FXXU5BTIC [september 2020, revC] CSC Version: A505FOJM5BTJ2 [october 2020, rev2] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: R58M67W8KPK Imei: 355396049783833 Imei2: 354410063648334 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Use stock firmware. Finished at local time: [10.20.20 12:41:56] WorkID: 111979795 A505F u5 IMEI repair done but patch not done? need help team |
10-20-2020, 11:49 | #1117 (permalink) |
Junior Member Join Date: May 2014 Location: mozambique .beira
Member: 2181127 Status: Offline Sonork: family Thanks Meter: 10 | chimera is onother level big update keep it up only chimera number one |
The Following User Says Thank You to amony For This Useful Post: |
10-20-2020, 12:01 | #1118 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | Hi don't work, what stock fw to use ? thanks. PDA Version: G970FXXU7CTF1 [june 2020, rev1] . .... . .... Reading data... Use stock firmware. Finished at local time: [10.20.20 12:50:37] WorkID: 111981121 |
10-20-2020, 12:02 | #1119 (permalink) |
Major Poster Join Date: Nov 2015 Location: Gujrat Age: 29
Member: 2484556 Status: Offline Sonork: 100.1670147 Thanks Meter: 17 | A505F U5 Patch cert done Chimera Mobile Phone Utility version: 26.37.0928 @ 2020-10-20 Printing phone history Patch Certificate 10/20/2020 10:56 AM Patch Certificate 9/12/2020 7:22 AM Patch Certificate 9/9/2020 4:47 PM Patch Certificate 9/9/2020 4:46 PM Repair IMEI 9/9/2020 10:51 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Carrier ID: XSG Sales Code: XXV Country Code: VIETNAM Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Apr 27 13:21:20 KST 2020 PDA Version: A505FDDU5BTE1 [may 2020, rev1] Phone Version: A505FXXU5BTE1 [may 2020, rev1] CSC Version: A505FOLM5BTE1 [may 2020, rev1] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: RZ8M9403QQK Imei: 35810410 Imei2: 3581041 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.20.20 16:00:35] WorkID: 111982571 |
10-20-2020, 12:11 | #1120 (permalink) | |
Insane Poster Join Date: Jan 2014
Member: 2110834 Status: Offline Thanks Meter: 9 | My Mistake Quote:
Chimera Mobile Phone Utility version: 26.37.0928 @ 2020-10-20 Printing phone history Repair IMEI 10/19/2020 11:34 PM Patch Certificate 10/19/2020 11:14 PM Patch Certificate 10/19/2020 10:59 PM Patch Certificate 10/19/2020 10:48 PM Patch Certificate 9/28/2020 12:02 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N976B Carrier ID: BTU Sales Code: BTU Country Code: UK & IRE Timezone: Europe/London Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue May 26 17:24:45 KST 2020 PDA Version: N976BXXU4CTE9 [may 2020, rev9] Phone Version: N976BXXU4CTE9 [may 2020, rev9] CSC Version: N976BOXM4CTE9 [may 2020, rev9] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON50005100 Serial Number: RFCM70060HF Imei: 866241041663314 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.20.20 10:36:40] WorkID: 111970322 Done thank Chimera | |
10-20-2020, 12:27 | #1122 (permalink) | |
Member: 1143337 Status: Offline Thanks Meter: 104 | Quote:
please post root method thx bro | |
10-20-2020, 12:32 | #1123 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, just read carefully the Log and can see how is been rotted: Quote:
10-20-2020, 12:44 | #1124 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | help to repair imei Code: Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Carrier ID: PHE Sales Code: XSG Country Code: UAE Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Nov 22 10:53:29 KST 2019 PDA Version: A307FNXXS2A*** [november 2019, rev9] Phone Version: A307FNXXS2ASK1 [november 2019, rev1] CSC Version: A307FNOJM2ASK2 [november 2019, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RF8M908D9RE Imei: 000000000000000 Imei2: 000000000000000 Battery Status: 4.33V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [10.20.20 16:42:55] WorkID: 111988914 |
