10-20-2020, 14:41 | #1129 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Rabat
Member: 1209155 Status: Offline Thanks Meter: 110 | Sm-g970f bit7 imei repaire still not supported Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Wed Jun 3 12:17:14 KST 2020 PDA Version: G970FXXU7CTF1 [june 2020, rev1] Phone Version: G970FXXU7CTF1 [june 2020, rev1] CSC Version: G970FOXM7CTF1 [june 2020, rev1] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RF8M130G88T Imei: 000000000000000 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [10.20.20 13:59:31] |
The Following User Says Thank You to wadieyou For This Useful Post: |
10-20-2020, 18:57 | #1133 (permalink) |
Major Poster Join Date: Nov 2015 Location: Gujrat Age: 29
Member: 2484556 Status: Offline Sonork: 100.1670147 Thanks Meter: 17 | A305F U5 Patch Cert Done Chimera Mobile Phone Utility version: 26.37.0928 @ 2020-10-20 Printing phone history Patch Certificate 10/20/2020 5:42 PM Patch Certificate 10/20/2020 5:40 PM Patch Certificate 10/20/2020 5:38 PM Repair IMEI 10/20/2020 5:35 PM Patch Certificate 10/20/2020 5:27 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A305F Carrier ID: KSA Sales Code: XME Country Code: MALAYSIA Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Wed May 6 19:22:36 KST 2020 PDA Version: A305FDDS5BTE3 [may 2020, rev3] Phone Version: A305FXXS5BTE3 [may 2020, rev3] CSC Version: A305FOLM5BTE3 [may 2020, rev3] Board Platform: UNIVERSAL7904 Modem Platform: SHANNON327 Serial Number: R58M84BRBBD Imei: Imei2: Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.20.20 22:52:09] WorkID: 112054989 |
10-21-2020, 02:14 | #1136 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: argentina
Member: 930014 Status: Offline Sonork: 1685379:ktre Thanks Meter: 84 | fail patch cert fail patch cert a305g u5 Quote:
10-21-2020, 08:53 | #1140 (permalink) |
Member: 2484556 Status: Offline Sonork: 100.1670147 Thanks Meter: 17 | is there any chance to add A205F U8 patch? Chimera Mobile Phone Utility version: 26.37.0928 @ 2020-10-21 Printing phone history Repair IMEI 10/21/2020 7:16 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A205F Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jul 9 14:38:26 KST 2020 PDA Version: A205FXXS8BTG1 [july 2020, rev1] Phone Version: A205FDDS8BTG1 [july 2020, rev1] CSC Version: A205FOJM8BTG3 [july 2020, rev3] Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: RZ8M6066W1H Imei: Imei2: Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-07-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [10.21.20 12:50:26] WorkID: 112114892 |
