04-29-2024, 12:39 | #1 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,027 | ⭐️29/04/2024⭐️New Exynos9610/9611 - 35 models - No Root,Any Bit,Any Version,Any Knox Get ready for a game-changing update! This latest update is packed with cutting-edge features by introducing support for Exynos 9610 and Exynos 9611. Don't miss this out — discover the variety of functions you can execute on your devices. This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device. The following devices are supported:
Available procedures: Restore / Store Backup, Unlock / Relock Bootloader, CSC Change, Change Serial, Factory Reset, Remove FMM, Remove FRP, Knoxguard Remove, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset () For more detailed information, please visit our Supported models page. If you'd like to see this working check out our videos:
Stay tuned! We'll continue tomorrow... *: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides here and our Test Point Database to learn more. **:if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available. Software version: 39.24.1218 Release date: 29 april 2024 Visit our Webshop: https://chimeratool.com/shop Join our Telegram: https://t.me/chimeratool_offical Like us on Facebook: https://www.facebook.com/chimeratool Read our Help & Documentation: https://chimeratool.com/docs Get Support: https://chimeratool.com/contact GsmEasy Distributor: http://www.imei.us GsmServer Distributor: http://www.gsmserver.com |
The Following 9 Users Say Thank You to Chimera Tool For This Useful Post: |
04-29-2024, 21:37 | #7 (permalink) |
No Life Poster Join Date: Nov 2006 Location: . Age: 35
Member: 400280 Status: Offline Thanks Meter: 83 | I Try with M315F u2 android 11... kg remove procedure and after process phone stuck phone power on with tag ERROR VBMETA m315fxxxxx Now in Download mode show: Current Binary: custom KG state: Locked OEM Lock: off (U) but obviously flash firmware doesn't work in this state. what can I do? |
04-30-2024, 04:29 | #8 (permalink) |
Freak Poster Join Date: Feb 2015 Location: GSM Community
Member: 2353766 Status: Offline Thanks Meter: 66 | Thanks a Ton for Samsung Galaxy A51 2019 (SM-A515F, SM-A515U, SM-A515U1, SM-A515W, SM-S515DL) Great UPdate |
The Following User Says Thank You to WWRG For This Useful Post: |
04-30-2024, 10:03 | #10 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 24,027 | Dear User, Can you try to run the KnoxGuard Patch procedure? Best Regards, ChimeraTeam Quote:
04-30-2024, 16:49 | #12 (permalink) | ||
Member: 400280 Status: Offline Thanks Meter: 83 | Quote:
05-10-2024, 09:22 | #13 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,027 | Dear User, We are working on the solution, please be patient. We will update the KG procedure soon. Regards, ChimeraTeam |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-13-2024, 11:21 | #15 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,027 | Dear User, You have to use Testpoint to connect the phone in EUB mode, but unfortunately, we do not have the TP picture for this model. Regards, ChimeraTeam |
