A022f imei repair failed I have tried up to 20 times, i get error failed or phone disconnected Chimera Mobile Phone Utility version: 32.00.1341 @ 2022-05-10 Printing phone history Repair IMEI 2022/05/10 07:51 Repair IMEI 2022/05/10 07:48 Get Info 2022/05/09 13:57 Repair IMEI 2022/05/09 13:53 Repair IMEI 2022/05/09 13:49 Repair started Unable to detect IMEI number and baseband version. It seems that the modem does not work or the network is unavailable/disabled. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A022F Carrier ID: XFA Sales Code: XFV Country Code: South Africa Timezone: Africa/Windhoek Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Tue Feb 8 20:22:24 KST 2022 PDA Version: A022FXXS3BVB1 [february 2022, rev1] CSC Version: A022FOJM3BVB1 [february 2022, rev1] Board Platform: MT6739 Network Type: GSM Multisim Config: DSDS Knox Version: v00 Warranty Bit: 0 Security Patch: 2022-02-01 Em Did: 922486CBB5F2 Repair imei... Repair imei failed. Finished at local time: [05.10.22 09:53:26] WorkID: 179532943 |
Chimera Mobile Phone Utility version: 32.00.1341 @ 2022-05-10 Printing phone history Repair IMEI 2022/05/10 07:53 Repair IMEI 2022/05/10 07:51 Repair IMEI 2022/05/10 07:48 Get Info 2022/05/09 13:57 Repair IMEI 2022/05/09 13:53 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A022F Carrier ID: XFA Sales Code: XFV Country Code: South Africa Timezone: Africa/Windhoek Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Tue Feb 8 20:22:24 KST 2022 PDA Version: A022FXXS3BVB1 [february 2022, rev1] Phone Version: A022FXXS3BVB1 [february 2022, rev1] CSC Version: A022FOJM3BVB1 [february 2022, rev1] Product Code: XFV HIDSw Version: A022FXXS3BVB1/A022FOJM3BVB1/A022FXXS3BVB1/A022FXXS3BVB1 Board Platform: MT6739 Modem Platform: MT6739 Serial Number: RZ8R50FLDLF Imei: 350843981215881 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,UNKNOWN Multisim Config: DSDS Knox Version: v00 Warranty Bit: 0 Security Patch: 2022-02-01 Em Did: 922486CBB5F2 Repair imei... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Operation in progress. Be patient! Do NOT disconnect the phone! Phone disconnected Finished at local time: [05.10.22 09:58:42] WorkID: 179533343 |
reply Dear Mr. Mean, Thank you for the report. We checked the posted Work. We found out that the device does not have a modem. The firmware does not have the - CP, phone - modules. Please reflash the device with the following firmware file: PDA Version: A022FXXS3BVB1 [february 2022, rev1] Phone Version: A022FXXS3BVB1 [february 2022, rev1] CSC Version: A022FOJM3BVB1 [february 2022, rev1] Then run the IMEI REPAIR once again. Best regards Sab Chimera team Quote:
i have flashed the 4 Flash file A022FXXS3BVB1 successfullyhttps://imgur.com/a/lwIdwns, but same problem, i have add some screenshot |
dialing *#06# take a bit time to display imei info |
reply Dear User, Thank you for the screenshots and for the feedback. Can you run the GET INFO service on the device with the Chimera Tool? If yes, please post the WORK ID from the job. We would like to collect more information from the issue. Best regards Sab Chimera team Quote:
Gathering info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A022F AP/PDA Version: A022FXXS3BVB1 [february 2022, rev1] CSC Version: A022FOJM3BVB1 [february 2022, rev1] CP/Phone Version: A022FXXS3BVB1 [february 2022, rev1] Serial: RZ8R50FLDLF IMEI: 350843981215881 IMEI2: 357475891215884 Product Code: XFV Unique Number: CQX00D38C067D38 Android Version: 11 FRP Lock Status: UNLOCK Successfully finished. Finished at local time: [05.10.22 13:17:25] WorkID: 179556713 |
reply Okay, thank you. Please try the method now. If you can, use it on another computer. Make sure that no other tool/software is running at the background. Also: please use another cable as well. What we can see is that the phone had no modem, but if you reflash it with stock firmware, and you do a full flash, the modem should be workable. (Sure, we can help you with the Computer detach if you can try it another Pc) Best regards Sab Chimera team Quote:
