10-24-2020, 22:47 | #1 (permalink) |
Insane Poster Join Date: Mar 2018 Location: Colombo
Member: 2821957 Status: Offline Thanks Meter: 30 | a600f u6 imei repair and patch done Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A600F Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Asia/Colombo Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Aug 14 13:26:30 KST 2020 PDA Version: A600FJXU6CTH1 [august 2020, rev1] Phone Version: A600FJXU6CTF1 [june 2020, rev1] CSC Version: A600FOJM6CTH1 [august 2020, rev1] Board Platform: UNIVERSAL7870 Modem Platform: SHANNON315 Serial Number: ********** Imei: *************** Imei2: *************** Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: ************** Repaired imei: 355990001585457 Current imei2: ************* Repaired imei2: 355990003584458 Successfully finished. Finished at local time: [10.24.20 21:49:11] WorkID: 112650966 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A600F Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Asia/Colombo Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Aug 14 13:26:30 KST 2020 PDA Version: A600FJXU6CTH1 [august 2020, rev1] Phone Version: A600FJXU6CTF1 [june 2020, rev1] CSC Version: A600FOJM6CTH1 [august 2020, rev1] Board Platform: UNIVERSAL7870 Modem Platform: SHANNON315 Serial Number: RF8K53460LA Imei: 355990001585457 Imei2: 355990003584458 Network Type: GSM SIM Status: ABSENT,UNKNOWN Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: 21.0:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.24.20 21:57:27] WorkID: 112651930 |
10-26-2020, 10:54 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,781 | reply Hello, Thank you for the post, if you have more successfully finished works, please let us know them as well! Quote:
