10-09-2015, 14:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Dharmapuri,Tamilnadu
Member: 1343981 Status: Offline Thanks Meter: 30 | Sm-j100h unlock done without root Dear Chimera Team Read The Logs Below , Successed Without Root Unlock Done Chimera Mobile Phone Utility version: 7.70.1439 @ 2015-10-06 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J100H Android Version: 4.4.4 Sales Code: XME PDA Version: J100HXXU0AOD1 [april 2015, rev1] Phone Version: J100HDXU0AOC1 [march 2015, rev1] CSC Version: J100HOLB0AOD1 [april 2015, rev1] Product Code: SM-J100HZKDXME HIDSw Version: J100HXXU0AOD1/J100HOLB0AOD1/J100HDXU0AOC1/J100HXXU0AOD1 Board Platform: SC8830 Serial Number: R51G705Z3TJ Imei: 352828071671497 Unique Number: C010F33121E52 Connections: AT,MTP Battery Status: 4.35V (94%) Network Type: GSM SIM Status: NETWORK_LOCKED SIM2 Status: ABSENT Knox Version: v00 Preparing... Reading images. Unlocking... The phone is not rooted. Please root to enable RIL method! 1. Disconnect micro USB cable 2. On dial window enter *#0808# or *#9090# 3. Select DM+MODEM+ADB 4. Tap OK on phone display 5. Connect micro UART cable 6. Click OK button If no service menu or the phone is not responding 1. Power OFF the phone 2. Disconnect micro USB cable 3. Connect micro UART cable 4. Power ON the phone 5. Wait until Android starts normally 6. Click OK button Testing availability. Be patient! Do NOT disconnect the phone! Trying on Prolific USB-to-Serial Comm Port (COM2) Port is not responding. Port is not responding. 1. Disconnect micro USB cable 2. On dial window enter *#0808# or *#9090# 3. Select DM+MODEM+ADB 4. Tap OK on phone display 5. Connect micro UART cable 6. Click OK button If no service menu or the phone is not responding 1. Power OFF the phone 2. Disconnect micro USB cable 3. Connect micro UART cable 4. Power ON the phone 5. Wait until Android starts normally 6. Click OK button Testing availability. Be patient! Do NOT disconnect the phone! Trying on Prolific USB-to-Serial Comm Port (COM2) Port is not responding. Port is not responding. 1. Disconnect micro USB cable 2. On dial window enter *#0808# or *#9090# 3. Select DM+MODEM+ADB 4. Tap OK on phone display 5. Connect micro UART cable 6. Click OK button If no service menu or the phone is not responding 1. Power OFF the phone 2. Disconnect micro USB cable 3. Connect micro UART cable 4. Power ON the phone 5. Wait until Android starts normally 6. Click OK button Testing availability. Be patient! Do NOT disconnect the phone! Trying on Prolific USB-to-Serial Comm Port (COM2) Check the phone's display during the process! Bypassing MSL... Be patient! Do NOT disconnect the phone! Processing... Be patient! Do NOT disconnect the phone! If needed use unlock code '12345678'. Restart phone by using the phone's menu if it does not restart automatically! Finished successfully. Finished at local time: [10.06.15 18:38:44] WorkID: 7256295 Br SatcomSingaram |
The Following 2 Users Say Thank You to SatcomSingaram For This Useful Post: |
