03-12-2018, 09:00 | #2941 (permalink) |
Freak Poster Join Date: Jun 2017 Location: SAUDI ARABIA RIYADH
Member: 2725078 Status: Offline Sonork: 1680162 Thanks Meter: 173 | [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J700F Sales Code: XSG Country Code: UAE Timezone: Asia/Riyadh Android Version: 5.1.1 [LMY48B] Build Date: Tue Jan 12 19:14:43 KST 2016 PDA Version: J700FXXU1APA2 [january 2016, rev2] Phone Version: J700FXXU2APE1 [may 2016, rev1] CSC Version: J700FOJV1AOFJ [june 2015, revJ] Product Code: SM-J700FZDDXSG HIDSw Version: J700FXXU1APA2/J700FOJV1AOFJ/J700FXXU2APE1/J700FXXU1APA2 Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: RZ8H81DRNEA Imei: 352347084##### Unique Number: CAJ03AD0EFE5F63 Connections: AT,MTP Battery Status: 4.32V (99%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-01-01 Data Encryption State: unencrypted Unlocking... Please unlock screen if closed. Trying on SAMSUNG Mobile USB Modem (COM74) Processing. Be patient! Do NOT disconnect the phone! Restarting. Unlocked. Finished successfully. Finished at local time: [03.12.18 10:53:53] WorkID: 34640788 |
03-12-2018, 13:19 | #2943 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | [HUAWEI VNS-L31 FRP REMOVE DONE Code: Chimera Mobile Phone Utility version: 16.82.0734 @ 2018-03-12 [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [03.12.18 13:53:41] WorkID: 34649568 |
03-12-2018, 14:19 | #2944 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Samsung G928A read codes done without root Samsung G928A read codes done without root via DIAG port |
The Following User Says Thank You to technomak For This Useful Post: |
03-12-2018, 15:22 | #2946 (permalink) |
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | HUAWEI WAS-LX1 FRP REMOVE DONE Code: Chimera Mobile Phone Utility version: 16.82.0734 @ 2018-03-12 [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [03.12.18 16:11:30] WorkID: 34656993 |
03-12-2018, 20:29 | #2947 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Unlock I9195 Chimera Mobile Phone Utility version: 16.82.0734 @ 2018-03-12 Printing phone history Info 12/03/2018 19:23:46 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9195 Sales Code: CHL Country Code: Chile Timezone: America/Santiago Android Version: 4.2.2 [JDQ39] Build Date: Mon Nov 11 23:30:42 KST 2013 PDA Version: I9195UBUBMK2 [november 2013, rev2] Phone Version: I9195UBUBMK2 [november 2013, rev2] CSC Version: I9195CHLBMK3 [november 2013, rev3] Product Code: GT-I9195ZKLCHL HIDSw Version: I9195UBUBMK2/I9195CHLBMK3/I9195UBUBMK2/I9195UBUBMK2 Board Platform: MSM8960 Modem Platform: MSM8930AB Serial Number: R21D8CSHTYM Imei: 357736055710048 Unique Number: C0890B014C2AE70 Connections: AT,MTP Battery Status: 3.96V (47%) Network Type: GSM SIM Status: ABSENT Warranty Bit: 0 Data Encryption State: unencrypted Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Checking root state... Rooted. Backing up partitions... Partition #1 stored Partition #2 stored Partition #3 stored Unlocking... Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is initialized. 5. Click OK button Trying on SAMSUNG Mobile USB Serial Port (COM21) Unlocked. Finished successfully. Finished at local time: [03.12.18 16:27:00] WorkID: 34679213 |
03-13-2018, 09:58 | #2948 (permalink) |
Freak Poster Join Date: Jun 2013 Location: South Africa
Member: 1961231 Status: Offline Thanks Meter: 36 | Huawei P10 LITE FRP DONE within sec Chimera Mobile Phone Utility version: 16.82.0734 @ 2018-03-13 [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [03.13.18 10:31:26] WorkID: 34700990 |
03-13-2018, 15:22 | #2950 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | samsung n9005 CERT write successfully samsung n9005 CERT write successfully Code: Chimera Mobile Phone Utility version: 16.82.0734 @ 2018-03-13 [Write certificate started]  Unable to detect imei number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N9005 Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Dubai Android Version: 5.0 [LRX21V] Build Date: Sat Dec 20 05:17:44 KST 2014 PDA Version: N9005XXUGBNL8 [december 2014, rev8] Phone Version: N9005XXEGBNL8 [december 2014, rev8] CSC Version: N9005OXAGBNL8 [december 2014, rev8] Board Platform: MSM8974 Modem Platform: MSM8974 Serial Number: RF8F80QXWXL Battery Status: 3.87V (44%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Data Encryption State: unencrypted Resetting MSL... Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Click OK button Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Click OK button Trying to enable diag port. Trying to enable diagnostic mode. Be patient! Do NOT disconnect the phone! The phone SM-N9005 is not available via ADB. 1. On dial window enter *#0808# or *#9090# 2. Select MTP+ADB 3. Tap OK on phone display 4. Click OK button The phone SM-N9005 is not available via ADB. 1. On dial window enter *#0808# or *#9090# 2. Select MTP+ADB 3. Tap OK on phone display 4. Click OK button The phone SM-N9005 is not available via ADB. 1. On dial window enter *#0808# or *#9090# 2. Select MTP+ADB 3. Tap OK on phone display 4. Click OK button The phone will reboot. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Failed. Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Click OK button On the port section of the device manager window check for the presence of the samsung serial port! Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Click OK button On the port section of the device manager window check for the presence of the samsung serial port! Trying on SAMSUNG Mobile USB Serial Port (COM309) MSL reset. Writing cert... 1. Disconnect micro USB cable 2. On dial window enter *#0808# or *#9090# 3. Select DM+MODEM+ADB 4. Tap OK on phone display 5. On some phones dialing *#0*# is necessary. 6. Connect micro UART cable 7. Click OK button If no service menu or the phone is not responding 1. Power OFF the phone 2. Disconnect micro USB cable 3. Connect micro UART cable 4. Power ON the phone 5. Wait until Android starts normally 6. Click OK button Testing availability. Be patient! Do NOT disconnect the phone! Trying on Z3X BOX Serial Port (COM6) Bypassing MSL... Be patient! Do NOT disconnect the phone! Null MSL detected. Processing... Be patient! Do NOT disconnect the phone! Writing cert... Be patient! Do NOT disconnect the phone! Restart phone by using the phone's menu if it does not restart automatically! Finished successfully. Finished at local time: [03.13.18 18:06:59] WorkID: 34715821 |
03-13-2018, 16:50 | #2951 (permalink) |
Member: 2725078 Status: Offline Sonork: 1680162 Thanks Meter: 173 | UNLOCK DONE Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G610F, Region: SWA, Provider: INS, PDA: G610FXWU1BQK3 Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Knox disabled. Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! It is necessary to restart the phone. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Finished successfully. Finished at local time: [03.13.18 18:45:43] WorkID: 34722623 |
03-14-2018, 06:58 | #2952 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | huawei p9 lite PRA-LA1..frp remove don.. huawei p9 lite PRA-LA1..frp remove don.. Code: Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-03-08 [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [03.08.18 11:41:19] WorkID: 34453371 |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
03-14-2018, 15:51 | #2953 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Samsung G920w8 Read codes done without root Samsung G920w8 Read codes done without root via Diag port Code: Chimera Mobile Phone Utility version: 16.82.0734 @ 2018-03-14 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920W8 Sales Code: TLS Country Code: Canada Timezone: Asia/Dubai Android Version: 7.0 [NRD90M] Build Date: Fri Nov 3 18:46:29 KST 2017 PDA Version: G920W8VLS5DQK1 [november 2017, rev1] Phone Version: G920W8VLS5DQK1 [november 2017, rev1] CSC Version: G920W8OYA5DQK1 [november 2017, rev1] Product Code: TLS HIDSw Version: G920W8VLS5DQK1/G920W8OYA5DQK1/G920W8VLS5DQK1/G920W8VLS5DQK1 Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: RF8GB2VBAGW Imei: 351559075286492 Unique Number: 1115FB3A824A3004 Connections: AT,MTP Battery Status: 4.24V (96%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-11-01 Data Encryption State: unencrypted Reading Codes... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port not found. 1. On dial window enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is up 5. Click OK button Serial port not found. 1. On dial window enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is up 5. Click OK button Serial port found on COM328 Reading data. Be patient! Do NOT disconnect the phone! Master Lock: 63808475 Network Lock: 70316461 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [03.14.18 18:42:19] WorkID: 34777732 |
03-15-2018, 16:53 | #2954 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | HUAWEI VNS-L31 REVIVED BY FULL FLASH FIRMWARE Chimera Mobile Phone Utility version: 16.82.0734 @ 2018-03-15 Printing phone history Update Firmware 3/15/2018 2:42:14 PM FRP Remove 3/15/2018 1:55:43 PM Update Firmware 3/15/2018 1:54:47 PM [Flash...] Open file... Checking signature... Checking integrity... Checking integrity on SHA256RSA. Checking integrity on CRC. Checking integrity on CURVER. Checking integrity on VERLIST. Checking integrity on EFI. Checking integrity on XLOADER. Checking integrity on FW_LPM3. Checking integrity on FASTBOOT. Checking integrity on MODEMNVM_UPDATE. Checking integrity on TEEOS. Checking integrity on TRUSTFIRMWARE. Checking integrity on SENSORHUB. Checking integrity on FW_HIFI. Checking integrity on BOOT. Checking integrity on RECOVERY. Checking integrity on RECOVERY2. Checking integrity on DTS. Checking integrity on MODEM_FW. Checking integrity on CACHE. Checking integrity on SYSTEM. Checking integrity on CUST. Checking version... Proccessing... Proccessing CURVER. Proccessing VERLIST. Proccessing EFI. Proccessing XLOADER. Proccessing FW_LPM3. Proccessing FASTBOOT. Proccessing MODEMNVM_UPDATE. Proccessing TEEOS. Proccessing TRUSTFIRMWARE. Proccessing SENSORHUB. Proccessing FW_HIFI. Proccessing BOOT. Proccessing RECOVERY. Proccessing RECOVERY2. Proccessing DTS. Proccessing MODEM_FW. Proccessing CACHE. Proccessing SYSTEM. Proccessing CUST. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Flashing... Flashing EFI. Flashing XLOADER. Flashing FW_LPM3. Flashing FASTBOOT. Flashing MODEMNVM_UPDATE. Flashing TEEOS. Flashing TRUSTFIRMWARE. Flashing SENSORHUB. Flashing FW_HIFI. Flashing BOOT. Flashing RECOVERY. Flashing RECOVERY2. Flashing DTS. Flashing MODEM_FW. Flashing CACHE. Flashing SYSTEM. Flashing CUST. Rebooting the device... Finished successfully. Finished at local time: [03.15.18 17:47:37] WorkID: 34837287 |
