08-15-2022, 18:44 | #4336 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | N960F Note 9 U9 Patch cert done Printing phone history Repair IMEI 8/15/2022 5:34 PM Reboot 8/15/2022 3:15 PM Reboot 8/15/2022 3:13 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N960F Carrier ID: BTU Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Aug 2 16:06:11 KST 2021 PDA Version: N960FXXS9FUH1 [august 2021, rev1] Phone Version: N960FXXS9FUH1 [august 2021, rev1] CSC Version: N960FOXM9FUH1 [august 2021, rev1] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: RF8K92WBYHK Imei: 353XXXXXXXXXXXX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-08-01 Em Did: 20000DCEB7FB7211 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [08.15.22 22:38:05] WorkID: 191593119 |
08-16-2022, 09:47 | #4337 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Qasir, Thank you for the feedback, great job. Best regards Sab Chimera team Quote:
08-16-2022, 10:50 | #4338 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | Samsung S9 G960F U17 Successful Patch Chimera Mobile Phone Utility version: 33.01.1235 @ 2022-08-16 Printing phone history Repair IMEI 8/16/2022 9:41 AM Read Cert 8/16/2022 9:17 AM Read Cert 8/16/2022 9:16 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Carrier ID: H3G Sales Code: VD2 Country Code: Germany Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Oct 19 11:22:58 KST 2021 PDA Version: G960FXXSHFUJ2 [october 2021, rev2] Phone Version: G960FXXSHFUJ2 [october 2021, rev2] CSC Version: G960FOVFHFUJ1 [october 2021, rev1] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: R58K90R25EV Imei: 354886XXXXXXXX Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-11-01 Em Did: 2009B70D902C0011 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the IMEI using: *#0011# The patch cert can be removed by repeating the process. After installing new firmware, the patch cert process must be repeated. Successfully finished. Finished at local time: [08.16.22 14:43:11] WorkID: 191657600 |
08-16-2022, 16:33 | #4339 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Qasir, Thank you for the report. Great work from you. Best regards Sab Chimera team Quote:
08-27-2022, 16:09 | #4340 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Northern Ireland
Member: 554722 Status: Offline Thanks Meter: 60 | P30 Pro VLOG-L09 Frp reset via testpoint and harmony cable Chimera Mobile Phone Utility version: 33.10.2125 @ 2022-08-27 Removing Huawei account Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [08.27.22 15:45:56] WorkID: 193119000 P30 Pro VLOG-L09 EMUI 12 12.0.0.134(c431e3r2p2) Nice work guys! Used test point then switched to harmony cable as the handset only appeared when using harmony cable? All done! Kind Regards |
The Following User Says Thank You to POACH For This Useful Post: |
08-29-2022, 09:39 | #4341 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Poach, Thank you for the report. Good work from you. Best regards Sab Chimera team Quote:
09-03-2022, 15:34 | #4342 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | S8 G950F Patch done Chimera Mobile Phone Utility version: 33.18.1125 @ 2022-09-03 Printing phone history Repair IMEI 9/3/2022 2:30 PM Reboot 9/3/2022 2:17 PM Repair IMEI 9/3/2022 1:52 PM Reboot 9/3/2022 1:38 PM Reboot 9/3/2022 1:25 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Carrier ID: XEU Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Apr 6 19:15:03 KST 2021 PDA Version: G950FXXUCDUD1 [april 2021, rev1] Phone Version: G950FXXUCDUD1 [april 2021, rev1] CSC Version: G950FOXMCDUD1 [april 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8K41YDKYX Imei: 35970XXXXXXXXXX Battery Status: 4.02V (85%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 00B48CB66132 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [09.03.22 19:33:23] WorkID: 193970990 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
09-05-2022, 09:03 | #4343 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Qasir, Thank you for the feedback! Great work you! Best regards Sab Chimera team Quote:
09-08-2022, 09:05 | #4344 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | S20 ultra Successful Patch Chimera Mobile Phone Utility version: 33.24.1305 @ 2022-09-08 Printing phone history Patch Certificate 9/8/2022 7:54 AM Patch Certificate 9/8/2022 7:38 AM Reboot 9/8/2022 7:04 AM Get Info 9/8/2022 7:01 AM Csc Change 9/7/2022 5:18 AM Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G988B Carrier ID: EUX Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 12 [SP1A.210812.016] [SDK 31] Build Date: Tue Jan 25 18:50:57 KST 2022 PDA Version: G988BXXUDEVA9 [january 2022, rev9] Phone Version: G988BXXUDEVA9 [january 2022, rev9] CSC Version: G988BOXMDEVA9 [january 2022, rev9] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Battery Status: 4.03V (78%) Network Type: GSM SIM Status: LOADED,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-02-01 Em Did: 2009F4AEC353C011 Preparing... Checking root access. The phone is rooted by: 24.1:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [09.08.22 13:01:49] WorkID: 194534821 |
09-08-2022, 09:16 | #4345 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Qasir, Thank you for the feedback. Good work from you. Best regards Sab Chimera team Quote:
09-08-2022, 11:29 | #4346 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | Sir its Miracle with Chimera Samsung G988B u13 Andriod 12 Security Patch Level Feb 2022 100% Done Really Great Team Chimera before operating i was afraid after patching the set will restarting but nothing all operation success. |
09-08-2022, 11:30 | #4347 (permalink) |
09-13-2022, 19:46 | #4349 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1392507 Status: Offline Thanks Meter: 38 | Chimera Mobile Phone Utility version: 33.29.1152 @ 2022-09-13 Read codes started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505G Carrier ID: PCT Sales Code: TPA Country Code: PANAMA Timezone: America/Havana Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Jul 23 05:29:12 KST 2021 PDA Version: A505GUBS9CUG4 [july 2021, rev4] Phone Version: A505GDXS9CUG4 [july 2021, rev4] CSC Version: A505GOWO9CUG4 [july 2021, rev4] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Battery Status: 4.16V (90%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2021-07-01 Em Did: 2013942C3D270611 Reading codes... Checking required conditions. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Switching to upload mode. Be patient! Do NOT disconnect the phone! Waiting for upload interface. Be patient! Do NOT disconnect the phone! Upload interface: SAMSUNG Mobile USB Modem (COM19) Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Data analysis in progress. Be patient! Do NOT disconnect the phone! Waiting for the server to respond. MCK/Master lock code: 31851358 NCK/Network lock code: 48092030 Subset lock code: 00000000 SP lock code: 00000000 CP lock code: 00000000 SIM lock code: 00000000 Successfully finished. Finished at local time: [09.13.22 09:34:54] WorkID: 195186244 |
The Following User Says Thank You to rodny19 For This Useful Post: |
09-14-2022, 09:41 | #4350 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Rodny, Thank you for the feedback. Great job from you! Best regards Sab Chimera team Quote:
