10-02-2023, 13:25 | #4682 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | A137F U3 Root & Patch Successful Done Chimera Mobile Phone Utility version: 37.14.1001 @ 2023-10-02 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A137F Carrier ID: EUX Sales Code: XSG Country Code: UAE Timezone: Asia/Karachi Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Mon May 29 10:28:37 +07 2023 PDA Version: A137FXXU3CWE1 [may 2023, rev1] Phone Version: A137FXXU3CWE1 [may 2023, rev1] CSC Version: A137FOXM3CWE1 [may 2023, rev1] Board Platform: MT6768 Modem Platform: MT6769 Imei: 35080xxxxxxxxxxx Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2023-06-01 Em Did: 20DA47B7A88EC411 Bootrom commands disabled: no Preparing... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.02.23 17:24:49] WorkID: 237299045 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
10-04-2023, 12:40 | #4687 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | tablet Alcatel OT-8094X Frp removed ok tablet Alcatel OT-8094X Frp removed ok |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
10-06-2023, 01:35 | #4689 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | samsung j7 prime g610m binario 8 imei repair ready... samsung j7 prime g610m binario 8 imei repair ready... thanks chimeratool team... |
The Following User Says Thank You to alexis_01 For This Useful Post: |
10-07-2023, 08:25 | #4690 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | G955F Successfuly Patched Chimera Mobile Phone Utility version: 37.16.1131 @ 2023-10-07 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Carrier ID: XEU Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Aug 12 16:20:15 KST 2019 PDA Version: G955FXXS5DSH5 [august 2019, rev5] Phone Version: G955FXXU5DSFB [june 2019, revB] CSC Version: G955FOXM5DSFB [june 2019, revB] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J40YFLKV Imei: 353589xxxxxxxxxx Imei2: 000000000000000 Battery Status: 4.05V (88%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-08-01 Em Did: 010D2EBDB1C2 Preparing... Servicing phone. Be patient! Do NOT disconnect the phone! Patching certificate... About 10-40 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. If you modify firmware, imei, csc, simlock status, or if *#0011# does not show "IMEI Status: OK", you should repeat the patchcert process. Successfully finished. Finished at local time: [10.07.23 12:24:31] WorkID: 238064654 |
10-09-2023, 17:57 | #4692 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | UMX U693CL FRP OK Code: Work log (238407299) Chimera Mobile Phone Utility version: 37.18.1107 @ 2023-10-09 Delete FRP partition Clearing FRP lock Finished at local time: [10.09.23 17:29:38] WorkID: 238407299 |
10-10-2023, 13:28 | #4693 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | J330FN U3 Patch Done Chimera Mobile Phone Utility version: 37.18.1107 @ 2023-10-10 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J330FN Sales Code: AMO Country Code: SPAIN Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Feb 12 16:34:43 KST 2019 PDA Version: J330FNXXS3BSB1 [february 2019, rev1] Phone Version: J330FNXXU3BSB2 [february 2019, rev2] CSC Version: J330FNAMO3BRK1 [november 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58K44GRM4N Imei: 35562508xxxxxxxxx Battery Status: 3.75V (30%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-02-01 Em Did: 040FEF0F9694 Preparing... Checking root access. The phone is rooted by: 25.2:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.10.23 16:43:16] WorkID: 238518034 |
10-10-2023, 23:55 | #4694 (permalink) |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | samsung a30s a307g binario 6 imei repair SAMSUNG A30S (A307G) ✅️ ROOT Y REPARAR IMEI BINARIO 6 BIT 6 BY CHIMERATOOL🌎🌎 very nice chimeratool |
10-11-2023, 08:43 | #4695 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | J530F U1 Patch Success Chimera Mobile Phone Utility version: 37.18.1107 @ 2023-10-11 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Thu Jun 8 23:15:44 KST 2017 PDA Version: J530FXXU1AQF5 [june 2017, rev5] Phone Version: J530FXXU1AQF5 [june 2017, rev5] CSC Version: J530FBTU1AQED [may 2017, revD] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8J7016T6M Imei: 352525xxxxxxxxxxx Battery Status: 4.16V (87%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-06-01 Patching certificate... Initializing. Reading modem. Be patient! Do NOT disconnect the phone! Preparing. Reminder! In case of new firmware flashing or modem replacement, the Patch Cert process must be repeated! Succeeded. Successfully finished. Finished at local time: [10.11.23 12:43:11] WorkID: 238655698 |
