09-16-2017, 17:40 | #32 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | P8 lite 2017 PRA-LX1 converted successfully to dual sim but build number changed NRD90M test-keys some orginal apps removed wallpapers an magazine also not working original build number is :PRA-LX1C432B115 WorkID: 26598658 regards |
09-30-2017, 10:55 | #36 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2760486 Status: Offline Thanks Meter: 0 | huawei p10 plus after the dual sim convert, unfortunately without function. I will not recommend this update with chimiera tool. I have now repaired it and repaired mainboard must be renewed. The cost is 145 €. |
10-07-2017, 11:14 | #39 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Nairobi,Kenya
Member: 390521 Status: Offline Thanks Meter: 57 | Not Successful please help Chimera Mobile Phone Utility version: 15.27.0922 @ 2017-10-07 Printing phone history Convert to Dual Sim 10/7/2017 9:49:51 AM Direct Unlock 10/7/2017 9:37:39 AM Direct Unlock 10/7/2017 9:34:40 AM [Converting to Dial Sim...] Searching for Manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Rebooting device to fastboot mode... Device found! Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Changing simcard slot information... Factory reset the device... Finished successfully. Finished at local time: [10.07.17 13:12:47] WorkID: 27518978 |
10-10-2017, 13:29 | #41 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2766338 Status: Offline Thanks Meter: 0 | Hi all, Can someone please help me converting my P10 Lite to Dual Sim. Carrier locked at the moment. Please feel free to contact me is any further information is needed. Thank you. Regards Sham |
11-01-2017, 22:27 | #43 (permalink) |
Freak Poster Join Date: Dec 2005 Location: morocco Age: 44
Member: 207447 Status: Offline Thanks Meter: 48 | p10 plus tested and worked Chimera Mobile Phone Utility version: 15.52.1052 @ 2017-11-01 [Converting to Dial Sim...] Searching for Manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Repairing second IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Rebooting device to fastboot mode... Device found! Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Changing simcard slot information... Factory reset the device... Finished successfully. Finished at local time: [11.01.17 21:27:15] WorkID: 28643692 |
11-14-2017, 16:26 | #45 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | very good work for my P10 Lite WAS-LX3 Finished successfully. Finished at local time: [11.14.17 11:18:15] WorkID: 29193707 |
