01-15-2021, 15:37 | #138 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Good day! The mentioned device - VTR-L09 - is actually supported for the "Convert to Dual Sim" service. You have to connect the phone in ADB mode to be able to do it. Also here you can check which other services are added to the device: https://chimeratool.com/en/models#q=VTR-L09 Sab |
01-24-2022, 14:48 | #139 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | PRA-LX1 Single To Dual SIM Convert Done ;) upload gif online Chimera Mobile Phone Utility version: 30.88.1240 @ 2022-01-24 Converting to Dual SIM... Factory reset notify window was accepted. Searching for manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Changing the model name to dual SIM variant... Changing simcard slot information... This may take a while. Be patient! Do NOT disconnect the phone! Factory reset the device... Finished at local time: [01.24.22 15:27:59] WorkID: 167070213
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
01-24-2022, 17:14 | #140 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, Thank you for the job, really great one! Best regards Sab Chimera team Quote:
02-14-2022, 20:14 | #141 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2640066 Status: Offline Sonork: 1675713 Thanks Meter: 0 | losing oem info Converting to Dual SIM... Factory reset notify window was accepted. Searching for manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Changing simcard slot information... This may take a while. Be patient! Do NOT disconnect the phone! Factory reset the device... Finished at local time: [02.14.22 20:09:13] WorkID: 169521951 phone original name vtr-l09 phone name after repair onyx d188 stockage before 4ram/64rom stockage now 2ram/16rom |
02-15-2022, 11:37 | #142 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Yassingsm, Please reflash the device with firmware that is compatible with a Dual SIM model version. Then restart the phone and check the phone info. Best regards Sab Chimera team Quote:
02-15-2022, 15:40 | #143 (permalink) |
Junior Member Join Date: Jan 2022 Location: shenzhen china
Member: 3004729 Status: Offline Thanks Meter: 1 | Finished at local time: [02.15.22 22:42:10] Work ID: 169613619 honor 8 lite worked!Great!! |
The Following User Says Thank You to simonfeng0668 For This Useful Post: |
04-26-2022, 09:33 | #147 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear bgfi, As Jepetu said before correctly. The Device should be reflashed with a firmware that was released exactly for the DUAL SIM phones. Best regards Sab Chimera team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
