02-22-2017, 21:05 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote: Dear user! I tell you that you have to use the option Reset FRP Lock - New because the other options do not even have this model supported. The file options are as follows: A710FXXU1AOL6 12/2015 A710FXXU1AOL8 12/2015 A710FXXU1APB1 02/2016 A710FXXU1APC3 03/2016 A710FXXU1APG2 12/2016 You should have to flash your phone with some of these files and if you have one of the latest versions like this A710FXXU2BPJ8 with Binary: 2 you will not be able to degrade to fix the FRP. If you have a firmware with "B" A710FXXU1BPI6 6.0.1 22.09.2016 it may not have a satisfactory result and that is because you need to have A710FXXU1AXXX "A" firmware as the options detailed above. | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
