02-16-2019, 02:28 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | G950f/ds imei repair done by chimera Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: XSG Country Code: UAE Timezone: Africa/Harare Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Sep 11 11:17:24 KST 2018 PDA Version: G950FXXU4CRI5 [september 2018, rev5] Phone Version: G950FXXU4CRI1 [september 2018, rev1] CSC Version: G950FOXM4CRI5 [september 2018, rev5] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: XXXXXX Imei: 3XXXXXXXX Battery Status: 4.30V (97%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-09-01 Data Encryption State: encrypted Repair imei... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Repaired IMEI: 3XXXXXXX Repaired IMEI2: 3X5XXXX If necessary, use the patch cert procedure. Succeeded. Successfully finished. Finished at local time: [02.16.19 02:50:36] WorkID: 52696617 PATCH CERT Chimera Mobile Phone Utility version: 20.24.1610 @ 2019-02-16 Printing phone history Repair IMEI 16/2/2019 00:49:26 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: XSG Country Code: UAE Timezone: Africa/Harare Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Sep 11 11:17:24 KST 2018 PDA Version: G950FXXU4CRI5 [september 2018, rev5] Phone Version: G950FXXU4CRI1 [september 2018, rev1] CSC Version: G950FOXM4CRI5 [september 2018, rev5] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: XX Imei: 3XXXXXX Battery Status: 4.24V (97%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-09-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Checking modem. Checking root. The knox is still valid. Because of the root, the warranty will void. Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image-based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G950F, Region: EUR, Provider: OPEN, PDA: G950FXXU4CRI5 Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling Knox. Be patient! Do NOT disconnect the phone! Knox disabled. Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server. Be patient! Do NOT disconnect the phone! After the process, the phone can restart once during startup. Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.16.19 03:02:05] WorkID: 52696723 JOB WELLDONE THANKS TEAM REAL GSM KINGS |
02-16-2019, 03:30 | #2 (permalink) | |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | Brother Quote:
Your IMEI Status And Network IS OK ? | |
