08-10-2019, 10:52 | #1 (permalink) |
Insane Poster Join Date: Dec 2014 Location: ethiopia
Member: 2312479 Status: Offline Thanks Meter: 7 | G975u t-mobile unlock done but still locked Unlock phone started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G975U Sales Code: TMB Country Code: USA Timezone: Africa/Addis_Ababa Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Apr 22 12:55:53 KST 2019 PDA Version: G975USQS1ASD9 [april 2019, rev9] Phone Version: G975USQS1ASD9 [april 2019, rev9] CSC Version: G975UOYN1ASD9 [april 2019, rev9] Product Code: TMB HIDSw Version: G975USQS1ASD9/G975UOYN1ASD9/G975USQS1ASD9/G975USQS1ASD9 Board Platform: MSMNILE Modem Platform: SM8150 Serial Number: R58M523T1ZA Imei: 357332100470844 Unique Number: 988F0A53484450464134 Connections: AT,MTP Battery Status: 3.83V (44%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-05-01 Data Encryption State: encrypted Unlocking... Unlocking. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! If necessary, use the following unlock code: 12345678 Successfully finished. Finished at local time: [08.10.19 11:43:39] WorkID: 69359617 Sent from my iPhone using Tapatalk |
08-12-2019, 10:39 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Hi, the main problem is that, you did not read the message what we sent in a notification window, just pressed YES / Continue button. Unlock not supported on the device. " Only AT&T, Cricket, Xfinity are supported! TMB model detected | A: Yes" Now your credits are refunded, but please in a future read the messages in a notification panel before you press YES / Continue. Best regards Nicole Quote:
04-19-2021, 09:49 | #3 (permalink) |
Freak Poster Join Date: Feb 2008 Location: gujrat
Member: 701404 Status: Offline Thanks Meter: 15 | hi team phone still network locked plz refund my cradtis Chimera Mobile Phone Utility version: 28.13.1511 @ 2021-04-19 Carrier relock started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G975U Carrier ID: TMB Sales Code: TMB Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Aug 25 16:25:00 KST 2020 PDA Version: FA90_G975USQU4ATH1 Phone Version: G975USQU4ATF1 [june 2020, rev1] Board Platform: MSMNILE Modem Platform: SM8150 Serial Number: R58M51V8P2T Imei: 357332100431655 Battery Status: 3.89V (56%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v00 Warranty Bit: 0 Security Patch: 2019-01-01 Em Did: 2030A514CE15FE11 Carrier relock... The operation is in progress. Be patient! Do NOT disconnect the phone! Carrier relocked. Successfully finished. Finished at local time: [04.19.21 12:59:16] WorkID: 131722212 Report Post |
04-19-2021, 10:15 | #4 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear User, Please provide the WORK ID from the problematic job, so we can check the issue with the device and with the credits too. Thank you. Best regards Sab Chimera Team Quote:
08-04-2022, 09:04 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear DHG89, Yes, we revoked the credits. Please do the process one more time. However, add extra locks to the device from a different country. In most cases with that little trick, you can make it work. Best regards Sab Chimera team |
08-09-2022, 10:06 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear User, The Carrier relock will not unlock the device, in fact you will get the opposite. More locks will be on the device. For example, if you select the T-mobile carrier, the phone will be locked to that carrier. Please place those SIM CARDS to the device which carriers you selected. Best regards Sab Chimera team |
08-09-2022, 15:36 | #9 (permalink) |
Junior Member Join Date: Aug 2014 Location: Holguin, Cuba
Member: 2240259 Status: Offline Thanks Meter: 0 | Yes, what i need is lock the phone to my country, i select the one that i use in my country and a random from france, the line that i use in my country its still not working. |
08-10-2022, 09:06 | #10 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear DHG, Let us know the WORK ID from the last job please so we can check what happened. Additionally, please reflash the phone and then run the CARRIER RELOCK once again, add all the network locks from your Country to the device. Best regards Sab Chimera team |
08-15-2022, 10:32 | #14 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear User, Once you reflash the device, the Carrier Relock changes will be removed from the device, so we do not suggest that. Best regards Sab Chimera team |
