Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member ![]() ![]() Join Date: Sep 2010
Member: 1401522 Status: Offline Thanks Meter: 4 | g985f u5 network problem atfer 7 day working i have g985f s20+ i change both imei with chimera tools and patch cert Done! after 7 days when i restart the phone sim cart note working airplan mode always show off -on and battry drain this code *#0011# dosent show any think i can imei and baseband in setting but both simcard not working until i flash again everything working fine! i root with both eftsu and maisk but the problem is sam! any one face this problem? this log Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: ACR Sales Code: ACR Country Code: GHANA Timezone: Asia/Tehran Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Wed Oct 14 09:01:14 KST 2020 PDA Version: G985FXXU5BTJ3 [october 2020, rev3] Phone Version: G985FXXU5BTJ1 [october 2020, rev1] CSC Version: G985FOXM5BTJ3 [october 2020, rev3] Product Code: ACR HIDSw Version: G985FXXU5BTJ3/G985FOXM5BTJ3/G985FXXU5BTJ1/G985FXXU5BTJ3 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N312DANH Imei: 35299906621**** Imei2: 352999066214**** Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Em Did: 200AF7746E0AC011 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35299906621**** Repaired imei: 35536211414**** Current imei2: 35299906621**** Repaired imei2: 35536311414**** Successfully finished. Finished at local time: [07.01.21 01:03:45] WorkID: 140356916 and this patch cert: Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: ACR Sales Code: ACR Country Code: GHANA Timezone: Asia/Tehran Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jun 23 15:38:23 KST 2020 PDA Version: G985FXXU3ATFG [june 2020, revG] Phone Version: G985FXXU3ATFG [june 2020, revG] CSC Version: G985FOXM3ATFG [june 2020, revG] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N312DANH Imei: 35299906621**** Imei2: 3529990662**** Network Type: GSM SIM Status: READY,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-07-01 Em Did: 200AF7746E0AC011 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [06.20.21 01:49:43] WorkID: 138976349 |
![]() | #2 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012
Member: 1787203 Status: Offline Thanks Meter: 22,167 | reply Dear alimoh, So currently the device is rooted and patched, but the phone cannot make any calls, there is no network, and the battery drains fast? Reflash the device again, make sure that you boot it up from recovery and then you run the imei repair and the patch. Best regards Sab Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
![]() | #3 (permalink) | |
Member: 1401522 Status: Offline Thanks Meter: 4 | Quote:
The phone rooted imei is changed and patch cert is done! After 7 days both simcard not working When i reflash ,root and pach cert again signal is coming back ! Its hardware problem or my work have mistake? | |
![]() | #4 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2010 Location: Inside Logic Age: 36
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,299 ![]() | Hi, interesting.... PDA Version: G985FXXU5BTJ3 [october 2020, rev3] Phone Version: G985FXXU5BTJ1 [october 2020, rev1] CSC Version: G985FOXM5BTJ3 [october 2020, rev3] and then another version: PDA Version: G985FXXU3ATFG [june 2020, revG] Phone Version: G985FXXU3ATFG [june 2020, revG] CSC Version: G985FOXM3ATFG [june 2020, revG] did you check this detail? |
The Following User Says Thank You to Shensohau For This Useful Post: |
![]() | #5 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,167 | reply Yes that is strange. I would recommend to reflash it with a new stock firmware and then perform the services again. As i mentioned above, run the phone from recovery and then do the processes. Quote:
![]() | #6 (permalink) | |
![]() | #9 (permalink) | |
I think this hardware problem becuse i remove simcards and the phone show sim inserted and always switch bitwin sim 1 and sim 2 | |
![]() | #11 (permalink) |
Member: 1401522 Status: Offline Thanks Meter: 4 | thank you for answer this problem happend after 7days use the phone flashed &rooted &and patch cert done https://s4.uupload.ir/files/screensh...tings_pxch.jpg https://s4.uupload.ir/files/screensh...tings_rtri.jpg no any simcard in mobile this software or hardware? Last edited by alimoh; 10-07-2021 at 00:11. |
![]() | #12 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,167 | reply Dear User, Flash a STOCK Firmware to the device, after that run the IMEI REPAIR and the PATCH CERT once more and then check the device. Best regards Sab Chimera Team Quote:
