08-06-2018, 14:35 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir! Here I leave the supported functions for this model. To remove FRP the firmwares that are supported are with Bit1, Bit2 and Bit4. Still firmware with binary:5 is not supported. Samsung Galaxy J7 2016 SM-J710F Read Codes Repair IMEI SW Change Unlock Device Info Firmware Compatibility Info Patch Certificate Read Cert Reboot Reset FRP Lock Reset Screen Lock Restore / Store backup Root / Unroot Set SIM Count Write Cert Paid features Read Codes Online 25 CRD / phone |
08-06-2018, 14:51 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | You could use this method. Download COMBINATION_OXA_FA60_J710FXXU5BRC1 https://androidfilehost.com/?fid=890129502657600341 Method 1: 1. Flash Combination The phone will start in the engineering menu and ad communication will be enabled but it is not necessary to use the FRP function 2. In these cases and to ensure that you have to enable USB debugging and do manual deletion and when you re-start the engineering menu, perform the activation of the development options again before doing flash Ideally, you can see the OEM option unlock. But, it does not matter and continue with the process. 3. Download from the support the firmware of 4 files in each folder and only check these options: A) BOOT - (check sboot) B) PDA - (tick Boot, Recovery, System) C) PHONE - DO NOT tick anything or load D) CSC - DO NOT tick or load The phone will start without an account, enable USB debugging and now you can see and enable OEM Unlock. Then they do a manual deletion and the phone is re-started without an account. Method 2: Once the FRP is successful, using these commands in a CMD window you should see the OEM unlock to do manual deletion. 1- adb devices 2- adb shell netcfg 3- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 4- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 |
The Following User Says Thank You to gcceleghg For This Useful Post: |
08-08-2018, 15:53 | #6 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | |
The Following 3 Users Say Thank You to gcceleghg For This Useful Post: |
