09-22-2015, 18:42 | #1 (permalink) |
Junior Member Join Date: Feb 2007 Location: Moon World
Member: 447268 Status: Offline Thanks Meter: 8 | help unlock Samsung SM-G316u Neo Lite Ace as I do to unlock the Samsung SM-G316u I have not found the solution to your tool. there is no root for this model? I'm already getting tired of trying and trying and always gives me error in image flash when I try root with root methods. always failed |
09-23-2015, 10:52 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Sir, please try to use an special root software, maybe it can help you. You can find some links for the special root software: https://chimeratool.com/help/Samsung-Rooting Best Regards: Nicole Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
09-24-2015, 22:08 | #3 (permalink) |
Member: 447268 Status: Offline Thanks Meter: 8 | Hello friends chimera team I've tried all the links to root the phone but I could not with any I feel so frustrated because they can not give the release to this equipment with other tools come with a read only code. |
09-24-2015, 23:02 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Use this! https://www.oneclickroot.com/root/sa...hu0aob1-4-4-4/ In my case, I made two phones as follows: Needless root 1- enable USB debugging expect them to detect and give unlock by UART 2- once ask activate menu of service we do is shut down the phone without unplugging 3- remove battery and cover with a tape contact BSI is to the middle 4- unplug the phone and turn it 5- connect usb, once the message can not be loaded off the phone 6- connect UART and give the ok button, wait for the end and off from the menu (do not remove battery) 7- take off once battery to remove the tape 8- placed opposite sim and place code 12345678 Last edited by gcceleghg; 09-24-2015 at 23:09. |
09-25-2015, 09:43 | #5 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear gcceleghg, thank you for the information and for your help! Best regards Nicole Chimera Team Quote:
09-25-2015, 17:40 | #6 (permalink) |
Member: 447268 Status: Offline Thanks Meter: 8 | Well there is the issue, I do not have any kind of com port or interface that is not possess any kind of UART cable. because it does not say you need internfaz UART, that baton and good will return the phone to the customer and a disappointment for not having been able to unlock the terminal, greetings and thanks for your answers. |
09-28-2015, 09:48 | #7 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Sir, could you write me the work id of the job please? If I know it I can check what was the exact problem and maybe I can offer you solution for the problem. Best regards Nicole Chimera Team Quote:
