06-07-2022, 06:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | HUAWEI AGR-L09 Bricked AGR-L09 huawei id removed option, now stuck on usb com 1.0 can't open fastboot or recovery please help.. Load Factory Fastboot 06-06-2022 11:12 AM Removing Huawei account Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [06.07.22 10:32:27] WorkID: 183124623 Loading factory fastboot Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [06.07.22 10:35:17] WorkID: 183124690 Regards, Saif. |
06-07-2022, 10:10 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,781 | reply Dear Saif, Please connect the device to the tool. You have to see two options: - Exit Factory mode - Load Factory fastboot You have to use one of them, to get the device out from the Factory mode, then you have to try to perform the REPAIR RECOVERY to restore the device fully. Just after that run the ID remove once again. Before you start it, make sure that you reinstall the Huawei drivers. Also, use another cable and Port for the connection. Best regards Sab Chimera team Quote:
06-07-2022, 11:35 | #3 (permalink) |
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | - Exit Factory mode - Load Factory fastboot stuck 46% Exit Factory Mode Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [06.07.22 16:02:50] WorkID: 183153281 Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [06.07.22 16:05:11] WorkID: 183153484 |
06-07-2022, 12:00 | #4 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,781 | reply Dear User, Please run a HARD RESET on the device. Which means press and hold the POWER button while the device is connected to the pc / tool. Hold the button for about 15-20 sec. Then click on the EXIT FACTORY MODE. Also make sure that you reinstall the Huawei drivers (In the chimera tool - settings menu) before you do that! Best regards Sab Chimera team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
06-07-2022, 14:09 | #5 (permalink) | |
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | Quote:
make pocedure as u said all error | |
06-07-2022, 14:09 | #6 (permalink) | |
make pocedure as u said, all error | |
