05-29-2022, 17:06 | #1 (permalink) |
Insane Poster Join Date: Jan 2010 Location: ++
Member: 1217701 Status: Offline Thanks Meter: 9 | Huawei MatePad T10 AGR-L09 Dead after FRP Remove with Chimera !! Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Rebooting phone to USB update mode Rebooting phone to USB update mode Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [05.25.22 19:44:54] WorkID: 181575693 Currently phone in Factory Mode unable to exit. Chimera team please tell me how to solve this issue... WBR |
05-30-2022, 09:39 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, Please run the EXIT FACTORY MODE or the LOAD FACTORY FASTBOOT method on the device. After that, you have to do the REPAIR RECOVERY and the FIRMWARE UPDATE. The device will be fully recovered. Best regards Sab Chimera team Quote:
06-03-2022, 17:15 | #4 (permalink) | |
Member: 1217701 Status: Offline Thanks Meter: 9 | Quote:
Both option doesn't work, i did then previously you can check job history.. Anything else ? | |
06-04-2022, 19:19 | #5 (permalink) | |
Exit Factory Mode Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [06.04.22 22:12:18] WorkID: 182864500 Loading factory fastboot Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Failed to read, try to hard-reset the phone Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [06.04.22 22:14:47] WorkID: 182864646 i think Board firmware is the only solution, let me know your final answer... WBR | |
06-07-2022, 11:37 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear GSM Style, We do not see any Exit Factory mode, nor Load Factory Fastboot methods done for that device in your Job history. Please let us know the WORK ID from those methods. Best regards Sab Chimera team |
06-10-2022, 19:53 | #7 (permalink) | |
WorkID: 182864500 WorkID: 182864646 You can check them ... Waiting for answer.... | |
06-13-2022, 12:35 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear GSM Style, Thank you for the feedback. Please do the following one: Please run a HARD RESET on the device. Which means press and hold the POWER button while the device is connected to the pc / tool. Hold the button for about 15-20 sec. Then click on the EXIT FACTORY MODE. Also make sure that you reinstall the Huawei drivers (In the chimera tool - settings menu) before you do that! Best regards Sab Chimera team |
02-06-2024, 10:27 | #9 (permalink) |
Junior Member Join Date: Dec 2009 Location: punalur,kollam,kerala
Member: 1182933 Status: Offline Sonork: [email protected] Thanks Meter: 3 | |
02-06-2024, 10:35 | #10 (permalink) |
