11-14-2019, 08:49 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: NOKIA
Member: 1663119 Status: Offline Sonork: iffi3 Thanks Meter: 213 | J260f.u3.imei repair problem Printing phone history Knoxguard Unlock 2019-11-13 04:34:12 PM Knoxguard Unlock 2019-11-13 04:22:49 PM Repair started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Mon Jun 3 18:31:32 KST 2019 PDA Version: J260FXXU3ASF1 [june 2019, rev1] Phone Version: J260FXXU3ASF1 [june 2019, rev1] CSC Version: J260FOJM3ASF1 [june 2019, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8K9345EZX Battery Status: 3.76V (22%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Repair imei... Checking modem version. This modem is not appropriate (J260FXXU3ASF1). Please downgrade if possible! Unsupported modem version. Finished at local time: [11.14.19 09:40:54] WorkID: 79330361 |
11-14-2019, 12:56 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Hi, just please re-flash your device with an other firmware what is contain older modem. Best regards Nicole Quote:
11-14-2019, 13:15 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | As Mr. Nicole says, re-flash your device with an other firmware what is contain older modem, but always in Bit 3 Also, you can use the Modem of this combination file that I leave here. COMBINATION_FAC_FG00_J260FPUU3ASF2 https://androidfilehost.com/?fid=6006931924117920870 |
04-13-2020, 10:31 | #7 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | SM-J260F U3 IMEI & Patch certificate Successfully finished Chimera Mobile Phone Utility version: 24.44.2205 @ 2020-04-13 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Mon Jun 3 18:31:32 KST 2019 PDA Version: J260FXXU3ASF1 [june 2019, rev1] Phone Version: J260FXXU3ASF1 [june 2019, rev1] CSC Version: J260FOJM3ASF1 [june 2019, rev1] Product Code: XFV HIDSw Version: J260FXXU3ASF1/J260FOJM3ASF1/J260FXXU3ASF1/J260FXXU3ASF1 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8M30FKKDK Imei: 35 Unique Number: CFN0040BC9B2DA5 Connections: AT,MTP Battery Status: 4.26V (99%) Network Type: GSM SIM Status: READY Multisim Config: SS Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [04.13.20 10:50:27] |
The Following User Says Thank You to ...::S.L.S::... For This Useful Post: |
