05-20-2022, 11:33 | #1 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Tajikistan
Member: 2704006 Status: Offline Thanks Meter: 181 | Huawei NOVA 6 5G WLZ-AN00 Reset Huawei ID error Code: Chimera Mobile Phone Utility version: 32.13.1420 @ 2022-05-20 Printing phone history Huawei Id & Frp Remove 5/20/2022 10:16 AM Removing Huawei account Uploading data... Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. Operation failed Finished at local time: [05.20.22 15:18:28] WorkID: 180889336 |
05-20-2022, 11:51 | #2 (permalink) | |
Member: 2704006 Status: Offline Thanks Meter: 181 | Quote:
Code: Chimera Mobile Phone Utility version: 32.13.1420 @ 2022-05-20 Printing phone history Load Factory Fastboot 5/20/2022 10:40 AM Huawei Id & Frp Remove 5/20/2022 10:18 AM Huawei Id & Frp Remove 5/20/2022 10:11 AM Huawei Id & Frp Remove 5/20/2022 9:55 AM Gathering information... Device Model: WLZ-AN00 Current software version: WLZ-AN00 2.0.0.230(C00E230R4P6) Hardware version: Ver3.0 Boot info: locked Image check: secure image verify success Android version: 10 Battery state: 3999mv Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.8 Phone info: NO MAIN VERSION VendorCountry: all/cn Base version: WLZ-LGRP3-CHN 102.0.0.230 Cust version: WLZ-AN00-CUST 102.0.0.230(C00) Preload version: WLZ-AN00-PRELOAD 102.0.0.6(C00R4) Finished at local time: [05.20.22 15:47:21] WorkID: 180892567 | |
05-20-2022, 14:21 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear bestsoft.tj, Thank you for the report. Most likely the problem comes from the drivers. Please do the following steps: 1. Reinstall the Chimera Tool Huawei driver (Settings menu) 2. Use another cable and USB port for the connection. 3. Before you start the Chimera, make sure that you close every running background tools and software. Best regards Sab Chimera team Quote:
