06-17-2020, 12:47 | #1 (permalink) |
Freak Poster Join Date: May 2018 Location: Baku Age: 37
Member: 2836410 Status: Offline Thanks Meter: 100 | Need Patch Cert for IMEI Duplicate? |
06-17-2020, 13:57 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, if you can read cert file, then, just edit cert in order to write imei 1 or 2, you decide... if you want write cert on IMEI 1 or 2 same IMEI just duplicate it in cert file... open as txt file |
06-17-2020, 15:10 | #4 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, answer is no, write cert procedure is permanent... do not bother wich imei do you write... procedure is permanent even after flash or factory reset |
06-17-2020, 17:21 | #5 (permalink) |
Member: 2836410 Status: Offline Thanks Meter: 100 | Thanks. If I write other phone's cert file to this model, it will be require patch cert operation. But you say that, if I write phone's original cert to the second imei, cert operation will be permament, ok? |
06-18-2020, 12:08 | #6 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, read CPID based cert files are only for devices from you read cert... so, you can't write on other device due will no pass security... device will be on NG state... |
06-19-2020, 09:53 | #8 (permalink) | |
Member: 2836410 Status: Offline Thanks Meter: 100 | Quote:
Yes, or Not? Nobody knows about it? | |
