07-06-2022, 15:41 | #1 (permalink) | |
Freak Poster Join Date: Nov 2013 Location: Venezuela-Falcon
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | not repair imei A107m bit 5 Quote:
07-06-2022, 15:46 | #2 (permalink) | |
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | the patching process does end but successfully but without raising a signal Quote:
07-06-2022, 18:33 | #4 (permalink) | ||
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | Quote:
07-07-2022, 10:11 | #5 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear Pablo, Run the IMEI REPAIR but make sure that you only repair the IMEI1. Then do the IMEI REPAIR again, and repair the second IMEI number. Also, we would recommend using the A107MUBU5BTL3 version for the repair. Best regards Sab Chimera team |
07-07-2022, 17:27 | #6 (permalink) |
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | I use the compilation that indicates me and nothing I must explain that when the software passed the baseband was unknown and I recovered it with a nv backup with unlocktool but if i can change imei if i use free software |
07-07-2022, 17:35 | #7 (permalink) | ||
I must explain that when the software passed the baseband was unknown and I recovered it with a nv backup with unlocktool but if i can change imei if i use free software Quote:
07-08-2022, 10:03 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Very strange. We have to investigate it a bit more, as we do not see exactly what can cause this problem. The firmware is is very much compatible with the method so there should be another issue. |
