02-26-2021, 16:52
#1 (permalink)
Member: 1564612
Thanks Meter: 12,343 | Note 10 (N970F/DS) ON BIT 6 FROM DEMO "IMEI REPAIR" + "PATCH CERT" DONE 100% Note 10 (N970F/DS) ON BIT 6 and Android 10, FROM DEMO "IMEI REPAIR" + "PATCH CERT" DONE 100% by Chimera.
Device Rotted and "LDU" REMOVED with EFT !! LAST STEP "PATCH CERT": INFO: Quote:
Chimera Mobile Phone Utility version: 27.59.1025 @ 2021-02-24
Get info started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-N970F
Sales Code: AUT
Country Code: Switzerland
Timezone: Europe/Rome
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Thu Jul 23 21:26:25 KST 2020
PDA Version: N970FXXS6CTGA [july 2020, revA]
Phone Version: N970FXXS6CTGA [july 2020, revA]
CSC Version: N970FOXM6CTGA [july 2020, revA]
Board Platform: UNIVERSAL9825
Modem Platform: SHANNON5000
Serial Number: R58xxxxx
Imei: 000000000000000
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2020-08-01
Successfully finished.
Finished at local time: [02.24.21 13:42:48]
WorkID: 126028299
| IMEIS REPAIR: Quote:
Printing phone history
Repair IMEI
24/02/2021
12:48
Repair started
Model: SM-N970F
Sales Code: AUT
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Repair imei...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Current imei: 000000000000000
Repaired imei: 35698xxxxxxxx
Current imei2: 000000000000000
Repaired imei2: 35696xxxxxxx
Finished at local time: [02.24.21 13:59:03]
WorkID: 126030014
| PATCH CERTS Quote:
Patch Certificate
24/02/2021
13:02
Patch certificate started
Model: SM-N970F
Sales Code: AUT
Imei: 3569xxxxxxxxx
Imei2: 3569xxxxxxxx
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
Checking root access. The phone is rooted by: 3.19:EFTSU
Reading data...
Patching certificate...
Checking root access. The phone must be started in recovery mode to be rooted!
To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power].
Without root the patchcert will not work!
Restarting phone in recovery mode...
About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
After installing new firmware, the patchcert process must be repeated.
Finished at local time: [02.24.21 14:07:55]
WorkID: 126031630
| From *#0011#
ROTTED 100% FINAL RESULTED, Note 10 from DEMO to GLOBAL working 100% BR
Allumts |
