p30 lite frp but testpoint not work help!!!!!! Gathering information... Device Model: MAR-LX1M Current software version: MAR-L01MEA 10.0.0.465(C185E7R2P4) Hardware version: Ver3.0 Boot info: locked Image check: secure image verify fail Android version: 10 Battery state: 3773mv Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.6 Phone info: (bootloader) main version do not exist in oeminfo! VendorCountry: hw/meafnaf Base version: MAR-LGRP2-OVS 10.0.0.465 Cust version: MAR-L01MEA-CUST 10.0.0.7(C185) Preload version: MAR-LX1M-PRELOAD 10.0.0.4(C185R2) Finished at local time: [08.17.21 15:58:26] |
reply Dear User, Can you please post the WORK ID from the process? So we can help you out. Best regards Sab Chimera team Quote:
test point process closed by huawei in all new versions |
reply Dear User, Did you face the same issue? If yes, can you please post the WORK ID from the problematic job? So we can check server-side what happens exactly. Best regards Sab Chimera Team Quote:
Hi,I have noticed several HUAWEI phones running andoid 11 dont connect hardware testpoint...i have NOVE 5T and P30 all not sensing hardware testpoint |
Hi, since lastest huawei updates, all security backdoors got blocked by lastest updates... need wait for new solutions about it... Quote:
reply Indeed. This is valid, the Huawei changed a few things in the devices so for the new Firmware Versions the testpoint is not workable anymore. Best regards Sab Chimera Team Quote:
u can downgraded it then use file put in com 1 |
reply Yes, technically you can flash an Android 10 version to the phone and in that case, it could work. Best regards Sab Chimera Team Quote:
after downgrade all usb modes stops working, fastboot,update mode ,adb all stop. after ota all works again. |
