01-06-2023, 18:05 | #1 (permalink) |
Insane Poster Join Date: Mar 2011 Location: FRENCH
Member: 1534420 Status: Offline Thanks Meter: 44 | P40 lite kirin 810 jne-lx1 demo remove Reading certificate... Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. Operation failed Finished at local time: [01.06.23 17:46:00] WorkID: 208722647 Modify Oeminfo Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. Operation failed Finished at local time: [01.06.23 17:49:31] WorkID: 208723028 can you check please work id to show what is the problem also i send you full information of phone Device Model: JNY-LX1 Current software version: JNY-L21 10.0.1.111D(C652E2R1P1) Hardware version: Ver3.0 Boot info: locked Image check: secure image verify success Android version: 10 Battery state: 3743mv Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.7 Phone info: (bootloader) main version do not exist in oeminfo! VendorCountry: demo/eu Base version: JNY-LGRP2-OVS 10.0.1.111 Cust version: JNY-L21-CUST 10.0.1.2(C652) Preload version: JNY-L21-PRELOAD 10.0.1.1(C652R1) Finished at local time: [01.06.23 16:30:22] WorkID: 208714139 i wait reply thanks !!!! also for your information service phone error message is very fast few second after clic on operation Last edited by redman24; 01-06-2023 at 18:13. |
01-07-2023, 14:39 | #2 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, you have wrong in remove Demo version, loock: Quote:
In OEMINFO you haven't changed nothing: Quote:
If want delete DEMO Modality, you cannot continue change OEMINFO with same demo version. | ||
01-07-2023, 14:51 | #3 (permalink) | |
Member: 1534420 Status: Offline Thanks Meter: 44 | Quote:
Reading certificate... Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. Saving IMEI backup: C:/Program Files (x86)/Chimera/Backup/Huawei/JNY-LX1_Group_2_Slot_1_86132404*******.imei Saving IMEI backup: C:/Program Files (x86)/Chimera/Backup/Huawei/JNY-LX1_Group_2_Slot_2_8613240424*****.imei Finished at local time: [01.07.23 14:35:28] WorkID: 208804234 Modify Oeminfo Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. New model name: JNY-L21 New vendor/country value: hw/eu We've just rebooted your phone into USB update mode, please do an USB firmware update without further reboot, because it might reinitialize the FW version compatibility flag Finished at local time: [01.07.23 14:40:02] WorkID: 208804850 Information Wifi MAC: 34:**:**:**:**:** SIM card 1 state: ABSENT SIM card 2 state: ABSENT Model name: JNY-LX1 Manufacturer: HUAWEI Device code: HWJNY Product name: JNY-LX1 ABI: arm64-v8a Multisim Config: dsds Language: en Region: US Android version: 10 Build id: HUAWEIJNY-L21 Build display id: JNY-L21 10.0.1.111(C652E2R1P1) Build description: JNY-L21-user 10.0.1 HUAWEIJNY-L21 111-OVS-LGRP2 release-keys Build date: Wed Feb 12 14:10:59 CST 2020 Build UTC: 1581487859 Build characteristics: default Build product: JNY Build fingerprint: HUAWEI/JNY-LX1/HWJNY:10/HUAWEIJNY-L21/10.0.1.111C652:user/release-keys Build security patch: 2020-01-01 Build SDK version: 29 NO NEED TO FLASH ONLY CHANGE OEM INFO FACTORY RESET DEVICE AND DEMO REMOVE | |
01-08-2023, 11:26 | #4 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, Yes now have done totally other procedure, (Correct Procedure). Have worked in "Factory Mode" that's RIGHT. Have removed "DEMO Modality" with Right Vendor/country: hw/eu and device now work. Unique important thing, do a "Firmware Update" writing a hw/eu firmware, using "JNY-L21 10.0.1.11 C432" if there's... or a little more high, otherwise you device Info will be always with a C652 (DEMO Firmware) inside. Loock one Perfect Procedure how goes done: p40-pro-els-nx9-converted-demo-global-success-chimera Br Allumts |
01-10-2023, 11:40 | #5 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @redman24 if you not to do a Firmware update, loock what show in "INFO": Quote:
This is a good procedure Complete, (Not to loock model, is the Right Procedure): Code: Update firmware HW/EU Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing BL2. Processing BOOT. Processing DTBO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing HIEPS. Processing SENSORHUB. Processing FW_HIFI. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PREAS. Processing PREAVS. Processing ERECOVERY. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing SUPER. Processing METADATA. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing IVP. Processing NPU. Processing HISEE_IMG. Processing USERDATA. Processing VERSION. Processing PRELOAD. Processing PATCH. Processing KPATCH. Opening the file Unpacking the archive... Unpacking the archive... Processing CUST_VERLIST. Processing CUST_VER. Processing PACKAGE_TYPE. Processing PTABLE_CUST. Processing VERSION. Opening the file Unpacking the archive... Unpacking the archive... Processing PRELOAD_VERLIST. Processing PRELOAD_VER. Processing PACKAGE_TYPE. Processing PTABLE_PRELOAD. Processing PRELOAD. Pre-processing APP files Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_Lculohptable.app Validating base file Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_FUHbhCupdate.app Validating customization file Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_paUKzAupdate.app Validating preload file Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_WoYCVRupdate.app Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_Lculohptable.app Flashing SHA256RSA Flashing CRC Flashing BASE_VERLIST Flashing BASE_VER Flashing PACKAGE_TYPE Flashing HISIUFS_GPT Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_oCDWeJptable.app Flashing SHA256RSA Flashing CRC Flashing CUST_VERLIST Flashing CUST_VER Flashing PACKAGE_TYPE Flashing PTABLE_CUST Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_ewtPOYptable.app Flashing SHA256RSA Flashing CRC Flashing PRELOAD_VERLIST Flashing PRELOAD_VER Flashing PACKAGE_TYPE Flashing PTABLE_PRELOAD Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_FUHbhCupdate.app Flashing SHA256RSA Flashing CRC Flashing BASE_VERLIST Flashing BASE_VER Flashing PACKAGE_TYPE Flashing HISIUFS_GPT Flashing XLOADER Flashing FASTBOOT Flashing BL2 Flashing BOOT Flashing DTBO Flashing VECTOR Flashing FW_LPM3 Flashing HHEE Flashing VBMETA Flashing TEEOS Flashing TRUSTFIRMWARE Flashing HIEPS Flashing SENSORHUB Flashing FW_HIFI Flashing MODEMNVM_UPDATE Flashing MODEMNVM_CUST Flashing MODEM_DRIVER Flashing RECOVERY Flashing RECOVERY_RAMDISK Flashing RECOVERY_VENDOR Flashing RECOVERY_VBMETA Flashing PREAS Flashing PREAVS Flashing ERECOVERY Flashing ERECOVERY_RAMDISK Flashing ERECOVERY_VENDOR Flashing ERECOVERY_VBMETA Flashing ENG_VENDOR Flashing ENG_SYSTEM Flashing HDCP Flashing CACHE Flashing RAMDISK Flashing SUPER Flashing SUPER Flashing METADATA Flashing VBMETA_SYSTEM Flashing VBMETA_VENDOR Flashing VBMETA_ODM Flashing VBMETA_HW_PRODUCT Flashing VBMETA_CUST Flashing ISP_FIRMWARE Flashing MODEM_FW Flashing IVP Flashing NPU Flashing HISEE_IMG Flashing USERDATA Flashing VERSION Flashing PRELOAD Flashing PATCH Flashing KPATCH Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_paUKzAupdate.app Flashing SHA256RSA Flashing CRC Flashing CUST_VERLIST Flashing CUST_VER Flashing PACKAGE_TYPE Flashing PTABLE_CUST Flashing VERSION Processing C:/Users/ripgs/AppData/Local/Temp/CHIMERA_WoYCVRupdate.app Flashing SHA256RSA Flashing CRC Flashing PRELOAD_VERLIST Flashing PRELOAD_VER Flashing PACKAGE_TYPE Flashing PTABLE_PRELOAD Flashing PRELOAD Restart the phone in normal mode Gathering phone information Processing phone information Current firmware version: 10.1.0.109 (C432E7R4P1) (hw/eu) @ ELS-NX9 Finished at local time: [05.16.22 19:00:20] WorkID: 180367237 Br Allumts | |
