09-13-2021, 18:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2499218 Status: Offline Thanks Meter: 44 | problem Network ng after restart Chimera Mobile Phone Utility version: 29.61.0725 @ 2021-09-13 Printing phone history Patch Certificate 9/13/2021 5:26 PM Patch Certificate 9/13/2021 5:23 PM Patch Certificate 9/13/2021 5:08 PM Repair IMEI 9/13/2021 5:06 PM Repair IMEI 9/13/2021 5:04 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610F Sales Code: XSG Country Code: UAE Timezone: Asia/Tehran Android Version: 8.1.0 [M1AJQ] [SDK 27] Build Date: Wed Oct 10 23:07:23 KST 2018 PDA Version: G610FDDU1CRJ4 [october 2018, rev4] Phone Version: G610FDDU1CRJ1 [october 2018, rev1] CSC Version: G610FOJV1CRJ3 [october 2018, rev3] Product Code: XSG HIDSw Version: G610FDDU1CRJ4/G610FOJV1CRJ3/G610FDDU1CRJ1/G610FDDU1CRJ4 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: Imei: Imei2: Connections: AT,MTP Battery Status: 3.74V (4%) Network Type: GSM SIM Status: ABSENT,READY Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-10-01 Preparing... Checking root access. The phone is rooted by: f822ca5b:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [09.13.21 22:03:30] WorkID: 150203438 Root was tested by different methods |
09-13-2021, 18:49 | #2 (permalink) |
Member: 2499218 Status: Offline Thanks Meter: 44 | Chimera Mobile Phone Utility version: 29.61.0725 @ 2021-09-13 Printing phone history Patch Certificate 8/26/2021 3:42 PM Patch Certificate 8/25/2021 4:22 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A720F Sales Code: THR Country Code: IRAN Timezone: Asia/Tehran Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Nov 15 19:58:53 KST 2019 PDA Version: A720FXXU9CSK3 [november 2019, rev3] Phone Version: A720FXXU9CSJ3 [october 2019, rev3] CSC Version: A720FOJV9CSL1 [december 2019, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58JA0ERM9X Imei: Imei2: Battery Status: 3.80V (10%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-12-01 Em Did: 0454CCAE79C4 Preparing... Checking root access. The phone is rooted by: f5593e05:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [09.13.21 22:19:17] WorkID: 150206320 |
09-14-2021, 09:33 | #5 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Dear User, Please reflash the device with the following firmware: A720FXXS9CTJ9 Then do the IMEI REPAIR and the PATCH CERT services once more. Make sure that you do it, while the Airplane mode is activated on the phone. Best regards Sab Chimera team Quote:
