![]() | #32 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2017 Location: Zanzibar
Member: 2667928 Status: Offline Thanks Meter: 14 | All htc old are not working on chimera Its only "development support" Sent from my SM-N9200 using Tapatalk |
The Following User Says Thank You to FunyFani For This Useful Post: |
![]() | #33 (permalink) |
Member: 2667928 Status: Offline Thanks Meter: 14 | Add efs files for imei null null repair for some models like note 3 Note 2 S3 S2 And others. Because no one can do it by now. We beleav you are great team please do it Sent from my SM-N9200 using Tapatalk |
![]() | #37 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,767 | reply Dear User, For the mentioned model (SM-G570F) we have the following service functions available: SW Change Unlock Device Info Firmware Compatibility Info Read / Write certificate Reboot Repair Device Root Key Reset FRP Lock Restore / Store backup Root/Unroot The Write cert options is there. What we missing is the Patch Cert. Of course your request will be forwarded to the developer team. Best Regards Chimera Team |
![]() | #43 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2011 Age: 59
Member: 1564612 Status: Offline Thanks Meter: 12,375 ![]() | Please Add the P9 Light Smart, (GR3-L01) and solve "AUTODECTED Phones", in Fastboot always same error of "UNKNOWN DEVICE" connected in Fastboot and STUCK here. Many Other model NOT Autodetected ...what happenes with this tool?, serrver is too FULL and not good to process or detected phones? |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
![]() | #44 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 25,767 | reply Thank you for your feedback. Our Developer team continuously working on the better service. I hope it will be fixed and added too shortly. Best regards Nicole Quote:
![]() | #45 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | Lg ms770 @ Chimera Tool Team please add this model for unlock and repair Imei , Model = LG MS770 Code: Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-28 [Development Support started. Thank you for your help!] Processing... Android Version: 4.0.4 Getting port information... Protocol test. #1 No LG modem ports found... waiting for one port to appear. No LG modem ports found... waiting for one port to appear. Protocol test. #5 Waiting for serial port to appear...  Please set the phone into download mode manually. Unplug the phone from USB. Turn off the phone. Press and hold 'volume up'. Replug the device to USB while holding 'volume up'. Waiting for download mode serial port to appear... If the device is stuck in dowload mode, remove the battery to reset the device.  Please enable 'Port Check Test'. If enabled, run the development support again. Thank you! How to enable 'Port Check Test' or 'DIAG port' on your LG phone: There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one  Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will appear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*<numbers in model name here># *#546368#*<numbers in model name here># In case you cannot get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. Process finished. Thank you for your support! Finished successfully. Finished at local time: [07.28.17 14:44:53] WorkID: 24339324 |
