10-11-2015, 21:46 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Marrakech
Member: 282206 Status: Offline Thanks Meter: 102 | s6 g920f v5.1.1 not supported [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920F Android Version: 5.1.1 [LMY47X] Sales Code: XEF PDA Version: G920FXXU2COH2 [august 2015, rev2] Phone Version: G920FXXU2COH2 [august 2015, rev2] CSC Version: G920FOXA2COH2 [august 2015, rev2] Product Code: SM-G920FZWAXEF HIDSw Version: G920FXXU2COH2/G920FOXA2COH2/G920FXXU2COH2/G920FXXU2COH2 Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58G41C5E0H Imei: 359937062826060 Unique Number: 03157DF38C95470C Connections: AT,MTP Battery Status: 4.02V (68%) SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 1 Unlocking... Android version 5.1.1 detected. Using recovery based method. Downloading custom recovery image. Be patient! Do NOT disconnect the phone! Checking image. Flashing custom recovery image. Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing recovery.img. Flashing cache.img. Restarting phone. Recovery mode will start. You do not have to do anything. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Calculating. Be patient! Do NOT disconnect the phone! Invalid keys. Unable to unlock. Finished at local time: [10.11.15 21:42:55] WorkID: 7335790 |
10-12-2015, 10:00 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear Sir, Unfortunately your phone us unable to unlock. The phone could not accept the necessary files and information for the unlock process. Without it you could not unlock the phone. If you got that error message: "Invalid keys. Unable to unlock." that mean the phone is not available for the unlock. Best regards Nicole Chimera Team Quote:
10-16-2015, 16:54 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Root this phone with thisSr. https://autoroot.chainfire.eu/ https://download.chainfire.eu/733/CF...xx-smg920f.zip All downloads contain .tar.md5 files flashable in ODIN as PDA. Make sure your device is in ODIN download mode (usually you can get there by holding VolDown+Home+Power when the device is turned off), then start the included Odin3-v1.85.exe file, press the PDA button, select the .tar.md5 file, and click Start. A modified recovery and cache partition will be flashed, which will install (only) SuperSU, then clean-up the cache partition and re-flash the stock recovery. For the root to work, the device must reboot into recovery. Most devices will do this automatically after flashing these files, but in case that does not happen, please boot into recovery manually. |
10-16-2015, 17:09 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | To root 5.1.1 I let you another file: https://download.chainfire.eu/733/CF...xx-smg920f.zip |
