10-19-2020, 11:39 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: nabeul
Member: 755635 Status: Offline Sonork: 0021622348367 Thanks Meter: 16 | samsung n975f s4 imie repaire + patc cert Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N975F Carrier ID: TUN Sales Code: FTM Country Code: France Timezone: Africa/Tunis Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue May 26 17:25:31 KST 2020 PDA Version: N975FXXU4CTE9 [may 2020, rev9] Phone Version: N975FXXU4CTE9 [may 2020, rev9] CSC Version: N975FOGC4CTE9 [may 2020, rev9] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8M834P4VX Imei: 358780106538270 Imei2: 358781106538278 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 358780106538270 Repaired imei: 358780106531119 Current imei2: 358781106538278 Repaired imei2: 358781106538229 Successfully finished. Finished at local time: [10.19.20 12:11:50] WorkID: 111809846 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N975F Carrier ID: TUN Sales Code: FTM Country Code: France Timezone: Africa/Tunis Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue May 26 17:25:31 KST 2020 PDA Version: N975FXXU4CTE9 [may 2020, rev9] Phone Version: N975FXXU4CTE9 [may 2020, rev9] CSC Version: N975FOGC4CTE9 [may 2020, rev9] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8M834P4VX Imei: 358780106531119 Imei2: 358781106538229 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.19.20 12:14:41] WorkID: 111810464 |
The Following User Says Thank You to wadda7e For This Useful Post: |
