07-19-2021, 16:20 | #1 (permalink) |
Freak Poster Join Date: Aug 2018 Location: india tamilnadu
Member: 2858217 Status: Offline Thanks Meter: 156 | Samsung s10 after patch certificate it's restart again and again any solution please Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Carrier ID: INS Sales Code: INS Country Code: India Timezone: Asia/Kolkata Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Tue Mar 23 22:02:35 KST 2021 PDA Version: G973FXXU9FUCD [march 2021, revD] Phone Version: G973FXXU9FUCD [march 2021, revD] CSC Version: G973FOXM9FUCD [march 2021, revD] Product Code: INS HIDSw Version: G973FXXU9FUCD/G973FOXM9FUCD/G973FXXU9FUCD/G973FXXU9FUCD Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RZ8M525674W Imei: 861428034235029 Connections: AT,MTP Battery Status: 3.87V (19%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 20010E8E09CFDA11 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.19.21 16:46:43] WorkID: 142887976 |
07-19-2021, 16:39 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Dear User, Please reflash the device. Then boot up the phone from recovery. Root the device once more, and just after that do the IMEI REPAIR and the PATCH CERT. Best regards Sab Chimera Team Quote:
07-20-2021, 10:18 | #3 (permalink) |
Member: 2858217 Status: Offline Thanks Meter: 156 | samsung s10 android 11 | while patch certificate bootloop i tried with airplane mode while patch certificate bootloop i tried with airplane mode,reboot from recovery mode all ways i tried,but bootloop device please help me solution Chimera Mobile Phone Utility version: 29.04.1243 @ 2021-07-20 Printing phone history Reboot 20-07-2021 09:05 AM Repair IMEI 20-07-2021 09:03 AM Reboot 20-07-2021 09:01 AM Repair IMEI 20-07-2021 09:00 AM Repair IMEI 20-07-2021 08:58 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Carrier ID: INS Sales Code: INS Country Code: India Timezone: Asia/Kolkata Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Jun 18 16:28:56 KST 2021 PDA Version: G973FXXSBFUF3 [june 2021, rev3] Phone Version: G973FXXSBFUE6 [may 2021, rev6] CSC Version: G973FOXMBFUE6 [may 2021, rev6] Product Code: INS HIDSw Version: G973FXXSBFUF3/G973FOXMBFUE6/G973FXXSBFUE6/G973FXXSBFUF3 Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RZ8M525674W Imei: 861428034235029 Connections: AT,MTP Battery Status: 3.93V (39%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-07-01 Em Did: 20010E8E09CFDA11 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.20.21 14:36:49] WorkID: 143011131 |
07-20-2021, 10:53 | #4 (permalink) |
Insane Poster Join Date: Jul 2018 Location: Tunis
Member: 2848399 Status: Offline Thanks Meter: 41 | chimera team knows about this mistake, but he still repeats this line "Please reflash the device. Then boot up the phone from recovery. Root the device once more, and just after that do the IMEI REPAIR and the PATCH CERT." This is not a solution The operation is successful on the tool, but on the phone it is different as everyone explained You have to respect everyone and post updates as soon as you can We pay annual subscriptions |
The Following 3 Users Say Thank You to Anis07 For This Useful Post: |
07-20-2021, 13:22 | #5 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Dear Anis07, We would not say that if the process would not be workable. Yes, this is not the ultimate solution for the issue and yes, this won't work for everyone. We know that. We do investigate the problem source - which is more likely the security patch level - so we have to upgrade the Patch Cert method. But for that we need time. We really hope that this time will be short. Best regards Sab Chimera Team Quote:
07-20-2021, 14:27 | #6 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1768975 Status: Offline Sonork: 1615342:cikaaca Thanks Meter: 50 | I can confirm that patch cert has bug When patch cert in android 11 constanly reboot on logo, without patch phone rooted works normaly Chimera team please update patch cert bug |
07-23-2021, 18:27 | #7 (permalink) |
Freak Poster Join Date: Aug 2020 Location: Uzbekistan
Member: 2964628 Status: Offline Thanks Meter: 87 | Android 11 not accept E-Token or Patch firmware.Why you are say Chimera mistaken (Cause is new Samsung security!!!)?I think there are no normal phone programmer.Just downgrade to Android 10 do your work. LINK TO FIRMWARE - https://androidfilehost.com/?fid=10763459528675558087 Press like button even my post helpful or helpless. |
08-18-2021, 09:38 | #13 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Dear User, We released updates for the MTK Samsung devices (we added IMEI REPAIR and PATCH CERT for a few new models) but regarding to this phone, we had no fixes yet. Best regards Sab Chimera Team |
08-19-2021, 09:08 | #15 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Dear User, Actually, we are working on the problem. The Samsung module will be updated/fixed. Of course, every client will receive a newsletter about it, once it is ready for release. Best regards Sab Chimera team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
