01-04-2017, 14:33 | #167 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Sir, please send us your user name. On the other hand please check your computer's date and time settings, if it is ok, check your firewall settings too. Something blocked the communication under the log in process. Best regards Nicole |
01-10-2017, 17:20 | #168 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | Samsung update | Improved Methods For The Latest Firmwares (S6/S6 Edge/A8) Dear ChimeraTool Users, ChimeraTool update: v 12.58.1438 10/01/2017 Samsung module update Added Improved Methods For The Latest Firmwares For Samsung Models (S6/S6 Edge/A8):
You still don't have license for ChimeraTool? Do you need Chimera Tool USB dongle?
01-11-2017, 06:32 | #172 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | sorry to say i am not satisfied with chimera samsung tool .i took this service for frp but every time it not only fail but also corrupted firmware and i have to repair set with other tool ......chimera blackberry service is best |
01-18-2017, 20:37 | #174 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, please Add Samsung G928F for FRP remove and Read/Write Cert.... FRP Reset in G928F always Failed... Work Id: #16829229, #16828938 Best regards allumts |
01-19-2017, 11:35 | #175 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, When you get the crash? For the second work: Did you tried all the listed firmware's? If yes try to use the simple "reset FRP " function. Best Regards Chimera Team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
02-01-2017, 18:04 | #177 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | Samsung Update: 01/02/2017 ChimeraTool update: v 12.80.1419 01/02/2017 Samsung module update Added Improved Methods For The Latest Firmwares:
Requires Root. The preparation of custom roots is in progress Added Improved Methods For The Latest Firmwares* :
* Where the Android Security Patch date is 2017-01-01 or above. For the "Direct Read Codes" method root is NOT required. "Direct Unlock" and "Read/Write Cert" methods need root. Android 7 is supported by the S7 models. Bugfix:
The Following 3 Users Say Thank You to Chimera Tool For This Useful Post: |
02-01-2017, 20:03 | #178 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, Can explain more clear this: Quote:
Br allumts | |
02-01-2017, 20:05 | #179 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | òoooooo , great tool, where to buy in india??? |
The Following User Says Thank You to vickyjadhav6161 For This Useful Post: |
